Front passenger side viberation and hard pull to the right.
I changed out my axel last night and it felt perfectly fine all last night and all morning. Then on my way to work I started getting a viberation and it began pulling to the right. Does this just sound like maybe it is just alignment issues.
Re: Front passenger side viberation and hard pull to the right. (97itr86)
Come on I got no love on the teg board. I figured someone here might have an idea.
It could be an alignment problem, but I don't know. My car pulled to the right cause I dropped my car. So yea...I have no clue, but it could be an alignment.
Re: Front passenger side viberation and hard pull to the right. (00 Hatch DX)
Did your car pull real hard to the right? I mean my car is on coilovers turned all the way down.
Former Moderator
We've installed axles that were already defective and they caused vibration under acceleration and torque steer.
Sounds like you might have gotten a bad inner joint.
Re: Front passenger side viberation and hard pull to the right. (B18C5-EH2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C5-EH2 »</TD></TR><TR><TD CLASS="quote">We've installed axles that were already defective and they caused vibration under acceleration and torque steer.
Sounds like you might have gotten a bad inner joint.</TD></TR></TABLE>
I was kind of thinking this because last night when I was going to put the axel in it was hard as hell to get the axel to flex at the end.
I forgot to add when I got to work I had some smoke coming out of the passenger side fender.
could be a sezied caliper, thats causes smoke, if the brake pad was constantly rubbing on the disc.
Any smell? and was your rim/lug nuts/hub ROASTING HOT ?
Re: Front passenger side viberation and hard pull to the right. (zc911)
yeah there was a slite smell. The smoke as coming from the engine bay out however. Rims and lugs were not hot I could touch them and no significant heat.
Re: (jigga008_99)
I am gonna try to drive it home tonight and jack her back up again. I might need to raise my car us some to help prevent these problems.
JDMhatchback20
12-23-2004 09:22 AM
