What's it mean when your rotor wobbles?
Old 10-16-2003, 09:45 AM
CXHatchback's Avatar
Default What's it mean when your rotor wobbles?
I've got some teg spindles that I'm using for my big brake setup, and I just noticed that when I put my new rotors on and spin them, they wobble and don't spin true. Does this mean the wheel bearing is bad?
Old 10-16-2003, 10:28 AM
SkankWorksDA's Avatar
if the wobble it could mean that they are warped, if it is whell bearing grab it and see if it moveif you pul or push on it i hope you get what i mean
Old 10-16-2003, 11:16 AM
Tony Starks's Avatar
Default Re: What's it mean when your rotor wobbles? (CXHatchback)
If your rotor tilts in and out your wheel bearing is bad.
Old 10-16-2003, 11:49 AM
slowdx's Avatar
Default Re: What's it mean when your rotor wobbles? (Tony Starks)
How do you fix a bad wheel bearing?
Old 10-16-2003, 12:45 PM
BatuKing's Avatar
Uh.. did you put the wheel in first then torque them to see if it still does it? if the wheel bearing is bad it would make noise also.
Old 10-16-2003, 01:26 PM
96-EJ6 B18C's Avatar
Default Re: What's it mean when your rotor wobbles? (slowdx)
The rotor will wobble a bit if the screws aren't used to attatch it to the hub...if you want to check to see if the wheel bearing is damaged snug all the lugs then try to wiggle the wheel toward and away from the car...if it moves at all you need a new wheel bearing...if that is the case a new one will have to be pressed in to the hub...bearing and labor to press it (assuming you can remove the hub assembly yourself) will be about $100-$120.
Old 10-16-2003, 01:38 PM
97itr86's Avatar
Default Re: What's it mean when your rotor wobbles? (96-EJ6 B18C)
Better off buying a new hub.
Old 10-16-2003, 04:16 PM
Default Re: What's it mean when your rotor wobbles? (BatuKing)
Well that blows. I did try tilting the hub and it did shake, so I guess using that one's out of the question. I didn't even think to check it while I was at the junkyard. And for $20 I can't really complain either.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BatuKing &raquo;</TD></TR><TR><TD CLASS="quote">Uh.. did you put the wheel in first then torque them to see if it still does it? if the wheel bearing is bad it would make noise also.</TD></TR></TABLE>
No it's not even on the car yet. THanks guys looks like I need a new set of spindles.
nightrider
07-24-2009 07:02 PM
SomeDude56
10-30-2006 10:49 AM
Takeoff
02-23-2003 11:11 AM
Takeoff
02-23-2003 09:22 AM
Quick Reply: What's it mean when your rotor wobbles?
