9000 grand mis-shift....
my buddy missed shifting from 5 to 4 and popped it into 2nd while going like 75...only stayed for like half a second...perminate damge? the engine seemed fine and just as strong, its a 2000 gsr, in a 95 hatch with a p28 chiped and rev limit removed
lucky i guess - if no idling problems, perhaps unusually loud ticking - JUST FOR ***** and Giggles ... check the timing belt to make sure it didnt skip any teeth.
do a valve adjustment, not like it hurts it - careful not to get ticking confused with the injectors - sometimes dirty injectors are loud ticks too.
Def check the timing belt though, if it wasnt pure tight it might of skipped a tooth, but if that was the case he would most likely have problems starting/ideling and pulling out of first. - Dont mishift again ... its happened to me ... top of 3rd into 2nd and i needed new valves. Sounds like your buddy is lucky - topic done
Re: (clm)
someone told me that the ticking was because it was a "heavy engine"....i duno what the hell is that about, but why im concerned is im most likley going 2 be buying the car off him soon, like later this week, should i back out? he treated it well and the car is real nice, i just dont want have alot of problems with it...espically head problems...they are not fun and expensive
Man xero you just want me to keep comin back CLM is correct, compression test and I suggest a valve adjustment is your best option to see if the motor is in best shape - if its a 2000 GSR you want 200+ compression/psi number obviously - If i was buying I wouldnt buy it with anything below 210/200 - 2k Motor is pretty new ... shouldnt lose to much compression.
yeah, we were going like 956 MPH down the garden state parkway, the tach spun around like 100 times, i think its ok though...but seriously, lol
hey plug in a vafc or something and check if tach is off - mine was when mishifted - it starts out as under 100 and gradually gets to 300 off at redline.
Re: (Chemicalviper)
http://www.c-speedracing.com/h...t.php
took at look at that, how long does that usually take? and can i rent one of those from like advance auto parts?
Re: (xerox445)
This is better link to a thread i started for compression tests - good link on there.
https://honda-tech.com/zerothread?id=628239
Make sure engine is warm. Not sure if you can rent the parts, i know you can buy the part for 40 bucks, and to have it done by a mechanic is like 50.
ok so i plan on doing this in a rest stop parking lot along the high-way, we are far apart...do i need a TQ wrench to re-tighten the plugs? and what do they get tourqued down 2 after they are done?
Re: (Chemicalviper)
positive on the plugs???? wouldnt the top of the chamber with a whole in it...with a piece of metal/ceramic need to be purdy tight when running like a 10.6 compression and gas exploding in it? i duno i thought i read that somewhere, but its also 2:15 in the morning, and ive got a buzz going...
your talking about spark plugs? yes hand tight, they shouldnt have to move around or wiggle - ive just checked mine after 6 months ... still tight as hell. but hey if you want torque them out.
Re: (xerox445)
