how to install Shifter Bushing ?
has anyone install one of these Shifter Bushing ? do these stuff really work?
[IMG][/IMG] http://cgi.ebay.com/ebaymotors...sting
Re: how to install Shifter Bushing ? (civictyper96)
Just did mine this weekend. took around an hour. Search and you can get directions. Thats what I did. It's pretty easy and the shifting is a TON better. There is One Bushing at the engine side, and a bushing by the shifter. There are two bolts that go through that one. Good Luck
Re: how to install Shifter Bushing ? (Caveman74)
I installed a set last week and I'm happy with them. shifting is much firmer, not sloppy anymore. I got the energy suspensions set. Didn't take long to install, but I was already under the car installing a new exhaust. Personally, I don't know that I would go through the trouble of getting under there, disconnecting the exhaust and all just for shifter bushings. Best to save the job for when you are already under the car (exhaust, short shifter, etc.)
http://www.hazone.com/hshiftbush.htm
Re: how to install Shifter Bushing ? (kommon_sense)
EASY SHIZNIT. Well, add a little PITA but that's pretty typical...All I did was jack up the front of my car, undo some bols here and there and slip the new bushings in. It is truly really easy, but the circle bushing can be a little tricky. And you might have to trim a little on the rectangle shaped piece to fit it into place since it's not as soft as the rubber ones. Overall, on a scale of 1 to 5 (5 being the hardest), I'd have to give it a 2. Only becuase of the PITA part that makes you want to say F#*% it. By the way, got Energy Suspesnio bushings too from http://www.suspension.com I love them. I just grind 2nd occasionaly when I shift hard. But that's no biggie.
Dan_the_MaN
11
10-18-2005 08:45 PM
02AccentGL
11-05-2003 08:25 PM
