VX block worth makin a mini-me??
sup all i just wanted to know if anyone has done a mini-mewith the vx block?? is it worth going through the hassle? if i run it im going to use a z6 head single ply z6 gasket and the basic i/h/e..so will it be potent? or should i just find a better block to play with?
get the ex/si tranny too. i cant remember the tranny code for it but a lot of people say the mini me is near worthless without the ex/si tranny. good luck with it, i'll be doing a z6 mini me on my dx soon, tranny to
Risky Business
Re: (Nerologic)
READ THIS: https://honda-tech.com/zero...age=4
We played around with the idea of a mini-me on the VX block...problem is, the VX pistons have a 7.50mm dish which would make the compression INCREDIBLY low and would counteract the gain in HP from the VTEC head...Mini-me on a VX will NOT work unless you change the pistons
Read the rest of my writeup too (all 4 pages...lots of good info) link is in the sig as well
Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic »</TD></TR><TR><TD CLASS="quote">well this is all going into an ef, so im going to be rocking a zc tranny</TD></TR></TABLE>
my bad on the into ef, i assumed into a 5th gen. BauleyCivic, i'll most likely be PMing you once i start my mini me swap.
Risky Business
Re: (Nerologic)
D15B7...flat top pistons, better R/S ratio than a D16Z6...
the best mini-me setup is P29 D16A1 pistons with VX rods in a D15B7 block with a D16Z6 or D16Y8 head...
or you could simply do any D16 block with the stock rods and P29 D16A1 pistons
Re: (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
or you could simply do any D16 block with the stock rods and P29 D16A1 pistons</TD></TR></TABLE>
That is probably the best option, no reason to fish around for VX rods when they are the same length as d16 rods, plus does anyone know if the VX rods are just as strong as say the d16z6 rods.
krysted9354
11-23-2008 11:48 AM
