maybe needing a new streering rack?
my freind says i am in need of either a new streering rack or tie rods. how much does that **** run anyways lol....being very lazy right now and i hate searching threads. i was also thinking if its the tie rods when buying a full gsr suspension wouldnt that supposedly come with new tie rods right????(sorry stupid when it comes to suspension lol..) anyways needs some help help a brotha out y0 thanks
Re: maybe needing a new streering rack? (dragboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dragboy »</TD></TR><TR><TD CLASS="quote">my freind says i am in need of either a new streering rack or tie rods. </TD></TR></TABLE>
for what reasons? it would help!
Re: maybe needing a new streering rack? (whoDAT)
i seem to hear a popping noise when turning the steering wheel a lil bit theres some play b4 the car turns and i just totally made power streering ever never usable again by going to manual and cutting all the lines out. the car is old now i know that and has seen alot of track time this year. so besides that i did want to revamp the suspension alltogether for next season if i do keep the car.( wnna autox and still reg. drag race)
Guest
Posts: n/a
could be axel. see if the tierod end is busted, balljoint..bellowboot=rock boot is leaking.. or get an alignment.. they will let u know or ask for a visual inspection (undercar) .. or jack ur car up and shake the wheel or tire back and fourth to see if any play.. so u can trace it to the suspension prob.. pm me if u confused
Re: maybe needing a new streering rack? (skatescrub)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skatescrub »</TD></TR><TR><TD CLASS="quote">if it is a rack, be prepaared for upwards of $500 </TD></TR></TABLE>
or $70-80 if you do a parts request on http://junkyarddog.com
Re: maybe needing a new streering rack? (HondaCutter)
When you removed power steering, did you loop the lines so that the rack would still have fluid in it? That fluid lubricates the rack and if you simply remove the lines and run the rack dry, then it will wear out very fast. If you've been driving around wih a dry rack, then I would say it's probably toast by now.
Alin
Alin
Re: maybe needing a new streering rack? (ProdriveWRC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ProdriveWRC »</TD></TR><TR><TD CLASS="quote">When you removed power steering, did you loop the lines so that the rack would still have fluid in it? That fluid lubricates the rack and if you simply remove the lines and run the rack dry, then it will wear out very fast. If you've been driving around wih a dry rack, then I would say it's probably toast by now.
Alin</TD></TR></TABLE>
u made the most sense dude
crowscare
12-17-2014 05:29 PM
Costco
12-27-2009 06:49 AM
msinsky14
15
05-03-2007 11:21 AM
