automatic tranny fluid change
New User
Re: automatic tranny fluid change (slowd16z6)
You have to bolts to remove. Use a 3/8in Rachet to lossen the lowest drain bolt. Drain fluid. Then remove top 17mm fill bolt. Plug drain, include new crush washer. Fill tranny, 2.2 liters. Plug fill bolt with new washer as well. Use search and type tranny fluid change, you will find some pictures in previous posted. I would recommend a manual, it is really simple as long as you have room to work.
1 Post
Re: automatic tranny fluid change (976)
hes talking about an auto tranny. just crack lose the bolt on the passenger side with a ratchet and remove it, take out the tranny dip stick and it will drain faster. when filling it up fill it up right through the dip stick hole with a long funnel. itll take about 3 quarts of atf before its full. the fluid level should be between the 2 holes on the dip stick. thats it.
New User
Re: automatic tranny fluid change (monicle)
Have fun filling 3 qts, which is too much, through the dip stick, dip stick Just messing with yea. Thanks for clearing up what I left out...
egyolk
04-29-2005 12:33 PM
EF-9SiR
11-29-2002 11:15 AM
