need help w/halo projector lights
does anyone know how to fix the halo projector lights, when there is fog and moisture.....? i attempted to re-seal it, i undo everythin, but i couldn't take out the lights, because the wires for the halo still connected! and the glue were on? what should i do? does anyone sellin oem lights, if u do how much u sellin them for? o ya my civic is 02 civic EX
Re: need help w/halo projector lights (sno83oky)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sno83oky »</TD></TR><TR><TD CLASS="quote">does anyone know how to fix the halo projector lights, when there is fog and moisture.....?</TD></TR></TABLE>
Huge problem with any aftermarket lighting equipment. Not really worth repairing. Try for a return or exchange.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sno83oky »</TD></TR><TR><TD CLASS="quote">does anyone sellin oem lights, if u do how much u sellin them for? o ya my civic is 02 civic EX</TD></TR></TABLE>
Check the classifieds forum.
Re: need help w/halo projector lights (D16Z6racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D16Z6racing »</TD></TR><TR><TD CLASS="quote">
Check the classifieds forum.</TD></TR></TABLE>
Very true. I know quite a few peopel with aftermarket lights that have moisture in them...sometimes within a month.
Re: need help w/halo projector lights (specv5150)
My gf got the Denji halo/projectors and it got moisture the first day it rained which happened to be the day after we got the ******* things. What I did was remove the cover from the behind the highbeam cuz the headlight unit isn't properly ventilated, run the headlight and it will start to clear or you can just leave it overnight and it will clear itself. Then I took the headlights off and ran silicone all around the headlight. I'm still gettin moisture but it's not from any cracks or leaks off the lens, my gf's front end is misaligned, you can tell just by looking at the headlights so water gets into the engine bay easily and leaks in through the back.
Ecskater1313
03-27-2004 03:27 AM
