Having trouble starting
Old 12-14-2003, 01:06 PM
GQ Cowboy's Avatar
Default Having trouble starting motor!!!
I am having trouble starting my car. The motor will turn over with no trouble, however, the spark plugs will not fire. I have removed one still connected to the spark plug wire - there is no spark when the engine is trying to be started. Does anyone have clue to what might be the problem?
Also, (not sure if this has anything to do with it) I recently installed some foglights. I'm getting power from the ACC switch (from the turn of the key). I don't think this is the issue, but I removed the splice and the car still won't start.
Old 12-14-2003, 01:12 PM
cxSHOE's Avatar
Default Re: Having trouble starting motor!!! (GQ Cowboy)
coil or your ignitor
Old 12-14-2003, 01:20 PM
GQ Cowboy's Avatar
Default Re: Having trouble starting motor!!! (cxSHOE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">coil or your ignitor</TD></TR></TABLE>
I'm not sure where these two items are. Can you please tell me where to locate these? To let everyone know I have a 92 5th gen civic, d16z6 motor. We replaced the distributor In August. The car ran fine a couple of days ago, and after installing the foglights - it just won't fire.
Old 12-14-2003, 05:14 PM
GQ Cowboy's Avatar
I replaced the distributor with a new one, it was under warranty. Installed correctly with all new components. Still won't spark at the spark plugs. I have also checked every fuse under the hood and under the dash = all okay. Does anyone have any idea what else might be wrong?
Old 12-14-2003, 05:55 PM
EvilPhu's Avatar
if it's not ignitor or module, check your ecu/ecu fuse if there is one, try to put another one in and see, borrow ur friend
Old 12-14-2003, 06:25 PM
HATCHingMN's Avatar
Hows your battalee??!! battery I mean??!!
93civicEX's Avatar
Default Re: Having trouble starting motor!!! (EvilPhu)
well maybe your coil is bad in the other one.....try testing the coil, instant message me if you need help to test
Old 12-14-2003, 06:26 PM
GQ Cowboy's Avatar
You may be right about the ECU. My friend with an Eclipse had the same thing happen to him. His car would not start and he checked the entire ignition system. I did the same. My question is does anyone have a used ECU for sale? I don't know if this matters I have a 92 civic hatchback si with D16z6 motor.
Old 12-14-2003, 06:55 PM
EvilPhu's Avatar
that suc, no friend with the same ecu, it's goona be tough
unless ur pretty sure about all the other problem, get a ecu, but first
check the ecu signal(wire)
Old 12-15-2003, 08:51 AM
GQ Cowboy's Avatar
Got it running. Thanks to all those who helped. for all those who care, it was the ACG fuse. 15a fuse was out, guess I didn't see it before. lets all have a beer for my rejoice.
jakescakesz06
01-04-2016 09:38 AM
thao0094
07-17-2007 08:56 AM
coldpimpin
04-10-2007 08:41 PM
candyteggy
11-10-2006 02:32 PM
dingusjt
06-29-2002 05:22 PM
Quick Reply: Having trouble starting
