Locate 99 Civic Rear Trailing arm??? ***PICS***
Can someone please use MS Paint or something and circle the rear trailing arm in this picture... if its even in this picture. If not, please describe to me where it is.
From my recent encounter with a curb, I have terrible camber issues on the rear left wheel. Here are the pics of the bad camber, and then of the setup w/out the wheel on. Mind you, this picture of the car with the wheel on was taken while on jackstands.... normally the camber gets MORE level when wheels are off the ground. NOTE: The wheel spins straight, just has a chunk on the inner well cracked out. No wobble... Also, the picture with the wheel off was during install, not after the accident. I don't know what it looks like back there right now...
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (citrEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by citrEK »</TD></TR><TR><TD CLASS="quote">any ideas that about what might be causing the nasty camber?</TD></TR></TABLE>
Can't see the camber captan because the car is jackup with no tire
If you have camber in the back, use some wahsers from home depot.
Use the search function to find out how.
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (sshaikh01)
alirght i'm mad bored so...
to fix the negative camber in the back, do what he said: just stick some washers between the compensator arm and it's mounting point on the chassis. 2 or 3 should do the trick, but you'll need more or less depending on how bad it really is, and the thickness of the washers. search for "washer trick".
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (jwn7)
Hey, I have two rear trialing arms in my basement, I can drive them out to you, or maybe we can work out a trade from the parts sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">yeah how'd you do a 5 lug conversion, and not have any idea what the trailing arm was? </TD></TR></TABLE>
Guest
Posts: n/a
Yeah, but what is that blue thingie?
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (Airbag Club)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Airbag Club »</TD></TR><TR><TD CLASS="quote">tanabe coilovers?</TD></TR></TABLE>
sustec pro ss =o)
sustec pro ss =o)
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (ransack)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ransack »</TD></TR><TR><TD CLASS="quote">its the clean looking black piece on the 4th pic.
replace that guy and you should be ok</TD></TR></TABLE>
so you think i stripped out my ingalls camber piece?
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (toolowsol)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toolowsol »</TD></TR><TR><TD CLASS="quote">Hey, I have two rear trialing arms in my basement, I can drive them out to you, or maybe we can work out a trade from the parts sol </TD></TR></TABLE>
if it is a trailing arm, and i need em that'd be cool... will they fit my CTR setup?? eh, i just sold the shell of the Sol, its sitting in my driveway waiting for the buyer to pick it up.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sshaikh01 »</TD></TR><TR><TD CLASS="quote">
Use the search function to find out how.</TD></TR></TABLE>
Hey smart guy why dont you go double check the pictures before trying to look cute and be the funny guy... Seems to me that pic 1 and 2 clearly show how bad the camber is!!!
CAPTAIN!!!!
CAPTAIN!!!!
Re: (MokujinX5)
before you worry about trailing arms.
INSPECT YOUR CAR FOR DAMAGE FIRST.
It could be..
the trailing arm
the compensator arm
the lower control arm
the hub assembly
or any combination of the above.
It could be..
the trailing arm
the compensator arm
the hub assembly
Re: (tonyXcom)
take you car to an alignment or good tire shop and they should be able to identify what part of the assembly is causing the poor camber. you may just need to have your camber kit re-adjusted, that is a camber kit i see right?!!?
-Bryan-
-Bryan-
Were you joking when you asked this question? You do realize you have a camber kit right? Get it adjusted.
Re: Locate 99 Civic Rear Trailing arm??? ***PICS*** (Slammed Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slammed Si »</TD></TR><TR><TD CLASS="quote">
CAPTAIN!!!! </TD></TR></TABLE>
klomast3r
09-06-2005 08:40 AM
