will drop car soon, need opinions on a camber
i have a 00 civic si... going to get h&r springs with tokico shocks.. springs have 2.25" drop in front and 2" drop in the back. should i get a camber kit for this, or just set my alignment with a toe of 0..... and if i do need a camber.. are both front and rear cambers necessarry? thx.
Re: will drop car soon, need opinions on a camber (K05eQuAzN)
yes, get a good one. i recommend SPC (not apc ) upper control arms with the pressed in ball joint. Works for me!
yeah, at least get the fronts. but i were you, i would save up and get the rear too. ingalls or skunk2 would be nice companies to look at. good luck.
Don't worry about the rear they can adjust the camber there by using shims or washers, it will cost u alot less then getting rear camber kit. unless u wanna be able to ajdust it then that is the simpiest thing to do.
Yeah get both, skunk2 or ingall. Plus find a shop that can get ur car up in the alignment rack when you lower it that much. Some of my friend can't even get on with 1.75 drop, lips,header,skirt,etc catches the rack/machine.
Re: will drop car soon, need opinions on a camber (EvilPhu)
i recommend skunk 2 for your car....they are great....just decide that you want coilover and slam your car......they will come through the engine bay over time.....I am referring to the camber kit......but they are a hot choice don't back out.....and look good....
Well if you're going to road race or auto-x, let the camber be, unless you want it to be adjustable. If you're going to drag, stock camber or 0 is good. Don't get a Progress kit, it's cheap and was a waste of money.
Re: (MrIllegalX)
I would say ingall front and shims for the back.
Just dont be stupid like me and screw back the bolts on with the washers when they're not straight and cross thread the hole. Now even the OEM ones wont go back in all the way.
goodluck with yours though.
Re: (FlamencoEsi)
Camber would be around -2+ since I have that drop on my car. Tires would wear a bit quicker as oppose to lower camber but get an alignment and have them correct your TOE and it shouldnt be that bad.
no you don't need a camber kit. after you lower the car, take it to an alignment place and tell them to set the toe to zero and not worry about camber.
oooo ya and for the people saying get skunk 2 camber kits BOOOOO on you do some studing they suck often come loose or even brake
CAMBER DOESN'T make tires wear fast TOE DOES
Re: will drop car soon, need opinions on a camber (slammed_93_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">no you don't need a camber kit. after you lower the car, take it to an alignment place and tell them to set the toe to zero and not worry about camber.
CAMBER DOESN'T make tires wear fast TOE DOES</TD></TR></TABLE>
well i change my mind droppin car wit tein's instead.. 1.9 in front and 1.75 in back... if i get a alignment and set toe to zero.. will i still have tire wear
Risky Business
Good post...finally someone reveals the truth!
Re: will drop car soon, need opinions on a camber (BauleyCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">
Good post...finally someone reveals the truth!</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K05eQuAzN »</TD></TR><TR><TD CLASS="quote">
well i change my mind droppin car wit tein's instead.. 1.9 in front and 1.75 in back... if i get a alignment and set toe to zero.. will i still have tire wear</TD></TR></TABLE>
no you wont need a camber kit, thats barely even lowering it, and your tires wont wear.
i lowered my car about 2.25 inches all around.. you know how much camber i have??
-0.5 in front -1.2 in rear. thats it. screw a camber kit
Re: will drop car soon, need opinions on a camber (SpyderZEX)
i have -2.0 and -1.75 in the front.....and i need a new upper and lower right side tie hook which is badly shaking from when i spun out. he suggested to heat up my knuckles but i will just get a camber kit. should i replace my control arms as well? how much does a ingalls or skunk 2 go for? thanks
Re: will drop car soon, need opinions on a camber (ek_jeremy)
wow im amazed that people are posting blantent lies in here, i don't know about ur situation ek_jeremy. but ABSOLUTLY DON'T GET A CAMBER KIT. and if you are just stupid and still want to waste money, then i say you better spend some goood money cause i haven't heard good things about most camber kits.
