gauge face installation 94 EX?
Does anyone have some information on how to install gauge faces in a 94 EX? the box instructions stink. i can't even get behind the glass that covers the gauges. i removed the two screws in the dash but i'm not sure what to do. Please help
Thanks
Thanks
Re: gauge face installation 94 EX? (ode1085)
search man
Look for like dash swap it will prolly show u how to remove the glass
glad to see someone else here from upstate NY
Down Since Day 1
Check this out, its for an EK but very similar. This has some good pics.
https://honda-tech.com/zerothread?id=704356
Re: gauge face installation 94 EX? (1 point 6)
well see my dash only has those two screws but then there is a whole black piece...lemme see if i can post a pic
ok here's my problem. I see these two screws but nothing else. I'm not just to force the whole black piece out right? If I can get a better pic, I'll post it.
you have to take the whole black peice out ..the vents and all ....then there is 4 screws holding ur cluster in
its just held in with 3 screws.......take the two top ones out, and then pop out your hazard button and you will see another screw behind there, take that one out and then the rest is just clips...it will take some force to get it out after the screws are out
Re: gauge face installation 94 EX? (92civeg)
there is a screw behind the hazard button too be careful when using a flat head screwdriver to get out the hazard button so that you don't scratch the black bezel.
Re: gauge face installation 94 EX? (R33CIVIC)
yea un screw the 2 from the cluster...
1 from behind the Hazard button...
I think there was one behind the left vent
Now pull the trim out and un screw the cluster from the inner dash 4 screws I think now unplug the harnesses
once you have the cluster out there is a few clips you gotta push down and slide to get the Plastic face off
depending on what your doing... you can do Amber bulbs now too...
ok you cant remove the needles if your replacing guage faces you have to slide them over the needles...
there is 2 lil screws in each section .... you'll see its very easy!
Re: gauge face installation 94 EX? (civiksiracer1)
There's those 2 you circled.
There's one behind the hazard button and one on the clock. After those 2 you just have to wrestle the black bezel out. After that unscrew the 4 screws holding the cluster in and unplug the connections from the back. After that's it's just common sense.
(Don't forget to take the hazard button off and unhook the clock of the bezel won't move.)
Risky Business
Re: gauge face installation 94 EX? (Del_Slowest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Del_Slowest »</TD></TR><TR><TD CLASS="quote">all your pics are Fooked man. it looks like a nice step by step if the pics worked</TD></TR></TABLE>
no we-todd is fooked...as usual keep checkin back they will come up eventually
pondnut
02-24-2006 06:24 PM
RustyDX
12-17-2001 03:23 PM
