99-00 Si Gauge Cluster in a 92-95 Civic!!?!?!?!?!?!?!?!?!?<--------
Ahhh Yes, does anybody have a write up or Pics and a write up
on how to d0 this? and yes for those who are going to say "SEARCH" i already
did and came up with shitty results but if you find some feel free to Clown me
and Post up the results i remember seeing a write up on it but it was just swapping the Gauge Faces...and not the cluster... S0 POST PiCS...OR PiCS AND INF0..THANKz....
Re: (JayDieM)
well i tried. everyone says "search. this has been covered a million times." when it really hasn't... haha. this is all i could really find for ya bro.
https://honda-tech.com/zerothread?id=96954
https://honda-tech.com/zerothread?id=689788
https://honda-tech.com/zerothread?id=73557
Re: (jwn7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jwn7 »</TD></TR><TR><TD CLASS="quote">well i tried. everyone says "search. this has been covered a million times." when it really hasn't... haha. this is all i could really find for ya bro.
https://honda-tech.com/zerothread?id=73557</TD></TR></TABLE>
Uh.........thanks? LOL i learned nothing but ya um...thanks NE-ways
Re: (JayDieM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JayDieM »</TD></TR><TR><TD CLASS="quote">
Uh.........thanks? LOL i learned nothing but ya um...thanks NE-ways </TD></TR></TABLE>
Did you READ all of the posts????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mps9506 »</TD></TR><TR><TD CLASS="quote">
You can make the Si gauage cluster work, it can be a pita though. I have a 2000si gauage cluster wired up in my 93. You need to either get the whole wiring harness or just the plugs (hopefully with at least some wire connected to each. Unfortunately I didn't document any of the wiring I did, but this is how I figured it out. If you look at the back of each gauge cluster you can figure out where each wire goes and thus what it is responsible for, just follow the leads where each wire connects to, label that wire whatever it is on your stock wires, then cut your stock connectors off, get the connectors with the wires from si. label where each wire goes to from each lead, then connect the proper wires from the si connectors to your stock wiring harness. plug it in, and you have the wiring done. It took me about 45 mins to do this when I figured out what to do. I think the hardest part to figure out was the turn signals.
No physically it won't fit in. I swapped in an entire dash from a totalled si. (I am about to take it out, never did fit a well as I wanted.) I am about to put my stock dash back in but plan on keeping my cluster, actually switching to an ex cluster, the redline throws me off when I drive hard, tend to shift too late. But it's the same thing basically, so I'll see what I can do, I should be doing this in about two weeks.
Re: 99-00 Si Gauge Cluster in a 92-95 Civic!!?!?!?!?!?!?!?!?!?<-------- (JayDieM)
And I REFUSE to believe you searched...
FIRST ONE I looked at had a link to the write up...
https://honda-tech.com/zerothread?id=602325
Re: 99-00 Si Gauge Cluster in a 92-95 Civic!!?!?!?!?!?!?!?!?!?<-------- (NonovUrbizniz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NonovUrbizniz »</TD></TR><TR><TD CLASS="quote">And I REFUSE to believe you searched...
https://honda-tech.com/zerothread?id=602325</TD></TR></TABLE>
ok oh yea p.s. ( i remember seeing a write up on it but it was just swapping the Gauge Faces...and not the cluster... )
ok oh yea p.s. ( i remember seeing a write up on it but it was just swapping the Gauge Faces...and not the cluster... )</TD></TR></TABLE>
Yeah I know there's both on here...
I just don't have time to look now...
The link I provided is the one where he swaps the SI guages into the EG cluster... there's another where they just put the whole SI cluster in... but it doesn't line up like stock.. it's kinda like the GSR cluster in a EG dash... there are gaps and it doesn't look as good in the end....
Oh and I don't know if you read the link I gave but half way down the first page there is a FULL write up on how to swap out the GUAGES... NOT just the faces... ALL the SI guages into the EG cluster body...
Essentially it will be an 00 SI cluster that fits properly... it's more work but it looks MUCH better and is the only "right" way to do it imo.
Here's some more.. I still haven't found "the" one....
If you really want to just swap in the whole SI cluster... I'd look for instructions on doing a GSR swap... It should be pretty similar though... I'm on page 4 of archieved search for "si cluster" and I haven't found anything more than I found on my first click last night...
Never mind... everything upto page 7 was useless... I'm not gunna search anymore...
Try looking in the sticky in "eg" of usefull how-to write ups... I bet it's in there.
Hey ******* check the link before you post it.
Jaydiem is asking for a 99 cluster in a eg not just the face plates
Im doing this project aswell and there is nothing on this subject on HT
only teg into eg teg in ek and ek face plates into eg
Re: 99-00 Si Gauge Cluster in a 92-95 Civic!!?!?!?!?!?!?!?!?!?<-------- (Beatkidd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beatkidd »</TD></TR><TR><TD CLASS="quote">Hey ******* check the link before you post it.
only teg into eg teg in ek and ek face plates into eg</TD></TR></TABLE>
THAT'S EXACTLY WHAT I POSTED...
I posted a full swap of all the GUAGES from an SI not just the faceplates...
And I've been trying to HELP him.
Stop being an E-thug you loser.
Im only saying that there is no ek to eg wiring write up that explains
all the wiring including the grey dots on duplicate wires and that fact that the ek has 3 harnesses ( 2 blue & 1 yellow ) while the eg has ( 2 grey 2 green)
I apoligize for calling you ******* but i hate when people tell you to search
when its not there
peace
when its not there
peace
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beatkidd »</TD></TR><TR><TD CLASS="quote">Im only saying that there is no ek to eg wiring write up that explains
when its not there
peace</TD></TR></TABLE>
PHAHAHHAAH WADDUP NiCK! hows the b16a?
when its not there
NP h0mie....its in and drivin??? oh yea you still sellin tha Si Rims???
when its not there
NP... I understand and the same thing drives me nuts...
I KNOW that there is a write up here somewhere... it may be linked to a user's outside site... but I KNOW it is around here somewhere...
It was up at the top only a few weeks ago... but like I said... I searched the archieves to page 7 on "si cluster" and it didn't show...
Who knows..
Good luck Jaydiem.
when its not there
Who knows..
Good luck Jaydiem.
Who knows..
Good luck Jaydiem.</TD></TR></TABLE> THankZ Doods
Who knows..
ok brandon im half way through with the wiring
(ctr cluster in ej) I'm gonna do a write up on this
aswell as the fabrication you have to do
peace
peace
