rear sway bay??
rear sway bay??
need some help here....which would be a better sway bar to go with...i can get a jdm CTR or ITR....i have a 5 lug on my car now but i'm not useing the ITR LCA....i plan on swiching to the ITR LCA....the only thing that i know right now about the sway bars is there both a 22mm but the endlinks dont look the same...in the front i'll be useing a SI sway bar....any EK guys have some feedback for me...whats your set up, how do you like, or should i go with a JDM ITR rear bar....i've herd that it was bigger
Re: rear sway bay?? (HYBRIDHATCH92)
I just got a SRR lower tie bar/sway bar combo from http://Perpetualconcepts.com. Its 19mm but from what i've heard its' supposed to work great. I'll let you know whats up when i get it installed. Btw i like you avatar .
Re: rear sway bay?? (SASIR2)
here we go now were getting somwhere....thanks for the info will be getting a lower tie bar after i get theses sway bars on...i need guys who are useing sway bars on a hatch
with the Si/CTR front sway make sure you get the Si LCA's & front forks. USDM ITR bar is 22mm while JDM is 23mm (22 is good enough for a hatch). Make sure you get Si REAR endlinks & definitely get a beaks kit (www.beaksproducts.com) to reinforce your subframe - which could rip out easily without the beaks kit. this is the set up i am going with, along with tein flex & edfc, 4 carbing bars & a-sport camber kit
note: not all rear lower tie bars will fit with ITR rear sway & beaks (search )
Re: rear sway bay?? (adirondackR)
i have all the stuff for the front i just wanted to know is there any difference between the CTR and ITR.....because there a big price difference in the two
Andrew 825SM
07-07-2003 01:19 PM
