im getting sick of this
ok well since i did my swap ive had problems with the driver's side front axle. i keep getting this thudding sound from under my feet, the axle doesnt seem to be going in perfectly straight, and it binds up a little bit. to remedy this i have done two things: changed the axles to dss axles which didnt fix it, and got new mounts cause one was blown and that didnt help. i mean its not as bad as before but not right yet. im starting to get pissed. any ideas on what to look for now?
Re: im getting sick of this (DragII)
yes acctually i had a shop look over it and theyre the ones that told me the blown mount might be an issue, i had them do the second axle install instead of myself cause i was thinking i might be ******* it up
Re: im getting sick of this (civichbb18c)
what motor what chassis???
have you inspected all the other mounts...
What kind of mounts do you have?
Some info would help folks out.
Re: im getting sick of this (NonovUrbizniz)
ok the car is 93 civic cx the motor is a 94 b18c1, the mounts are the hasport DCSTK kit:
1992-1995 Honda Civic
1993-1997 Del Sol
1994-2001 Acura Integra
Integra Engine Swap Mounts
Hydraulic Transmission
the axles are the driveshaftshop honda level one hybrid axles
hope that helps, i was thinking maybe it could be wheel bearing but i was told that was ok
1993-1997 Del Sol
when you swap the axle is it better for a little while, or bad from the get go?
if the axles, wheel bearings, mounts ect...all check out...you might need to have your differential checked out.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civichbb18c »</TD></TR><TR><TD CLASS="quote">notice above i was told they were fine</TD></TR></TABLE>
Oh yea. I remember reading that too. I'm so out of it today.
1 Post
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DragII »</TD></TR><TR><TD CLASS="quote">when you swap the axle is it better for a little while, or bad from the get go?
if the axles, wheel bearings, mounts ect...all check out...you might need to have your differential checked out.</TD></TR></TABLE>
Never would have thought of that.
Re: im getting sick of this (JDM-97CX)
when we put the new axles in it was def. better, it almost seemed to go away then it acctually got worse but not as bad as before
1 Post
how many miles befoer the new axles start making noise again?what brand axles are you using?some of the auto parts stores remanufactured axles are pure ****...i've had a few that made noise right out of the box.
chris
chris
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM-97CX »</TD></TR><TR><TD CLASS="quote">have you checked wheel bearings lately?</TD></TR></TABLE>
u were TOLD they were OK... if i told you your car ran 11's would that make it a reality?
SloCivicHMM
05-06-2002 05:36 PM
