97 Civic Wiper/Washer - fluid sprays but wipers don't activate
Hey everybody,
Just signed up and hoping someone on this fourm can help me out. The issue I'm having is when I pull back on the wiper switch for the washer fluid to spray it does, but the wipers dont automatically activate. Im not sure if this is how its supposed work or if there is a problem with the wiper motor, multi-function switch, or possibly the ICU. Please help this is getting annoying having to spray and click the wipers on to clear the windshield. Thanks
1997 Honda Civic EX Coupe, d16y8 vtec
Oh look, I can change this
Re: 97 Civic Wiper/Washer issue
Some Civics have this feature, some do not. All USDM 5G Civics do not have it. All CDM 5G and 6G Civics do. Some USDM 6G Civics do not have it, but I always thought this was only the lower models (like the CX hatchback), not the upper ones like the EX. Someone may have replaced your ICU with a lesser one, or else that function has stopped working.
You can pick up a replacement ICU at a junkyard for probably about $10.
The 96-00 Service Manual wiring diagram for the ICU suggests that some vehicles did not receive combined wiper-washer operation. I presumed this was the lower models. However, Honda EPC says all 96-00 Civics got the same ICU, but maybe on some vehicles it was not wired up? I don't know. To quote Roger Daltrey: "Certain things, I can't explain."
Wow. I thought that the auto wipe thingy was standard. Learn something new each day.
92 VX hatch
93 EX coupe
98 LX sedan
98 EX coupe
99 EX coupe
98 Integra GS sedan
All of which wipe/d as I pulled back to spray fluid.
92 VX hatch
93 EX coupe
98 LX sedan
98 EX coupe
99 EX coupe
98 Integra GS sedan
Re: 97 Civic Wiper/Washer - fluid sprays but wipers don't activate
Interesting. I'm guessing if you add a wire in the correct spot on the ICU and splice it to the washer's WHT/BLK then you can add this feature to your DX ... provided the ICUs are indeed identical.
Doubtful that the 92 and 93 had this feature, unless the vehicles were CDM or had been retrofit with a CDM ICU (or newer USDM ICU with that feature) and had the appropriate wire added.
Circuit diagrams in the USDM 92 Civic service manual indicate that some 92 Civics had said feature.
I had to retrofit this feature on my (originally) USDM 93 Si Hatchback. (Actually, I used an ICU from a 98+ CR-V so I could get a lights-on indicator and an intermittent rear wiper.)
Indeed they did ... only the CDM ones. Check the ICU diagrams on 23-160 and 23-161. Note Pin A7 on the CDM is present as well as a BLK/GRN from the washer switch to washer motor. None of this is present on the USDM diagrams.
I owned the 93 almost 8 years ago, so it is hard to remember exactly, but for the life me, I could swear it was USDM.
i actually like not having it wipe. when dealing with snow + salt spraying on the windshield, i like being able to control how many times it goes across the windshield. 1 extra wipe and it's all streaks.
I had this "feature" (or lack thereof) on my originally-USDM 93 Hatchback here in Canada, and all I could think of when I used it was: "CHEAPSKATE ASIAN IMPORTS". It was one of the first things I upgraded.
Seagull Management
That was my take on it. I'm Canadian so it wipes, but a lot of times I would like to spray first, especially when there's sand all over the windshield.
