95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
ok so i did i z6 swap in my dx coupe but now i have codes 6 10 19 and my car have a hard time starting i dont know where to start the wiring and everything seems to be correct and also my battery seems to be draining rapidly fast too the alt is ok had it tested...
Re: 95 civic DX/z6 swap - hard to start and CEL codes 6, 10, and 19
Reset the ECU to see whether any of the codes repeat.
What ECU are you using?
Do you have a manual transmission? Code 19 indicates that your ECU is for an automatic transmission.
yeah its a manual i cleared most of the codes now im stuck on code 19 which means i just gotta get a new ecu oh and im running a p28
you don't have to get a new ecu. if you have a little bit of soldering skills you can take out R18 and R17 then put a jumper wire in place of R18. just be sure to use a low watt soldering iron.
blaze_125
09-10-2008 09:39 AM
jimmy o.
12
05-14-2008 04:16 AM
skaterdx
08-26-2004 11:11 PM
