94 Del Sol Si - Any bolt ons for more power and/or torque?
The Grumpiest
Re: 94 Delsol Si
An Automatic? You messed up. Not getting any power out of that unless you swap to a manual transmission. Even then it's a D-series engine. The ONLY thing you can do to get power out of it is turbocharge it.
On vacation
Re: 94 Delsol Si
You already have the highest HP d-series motor they made, so no other parts of other cars will increase power.
You really cannot significantly increase the HP of a d-series without adding forced induction or raising the compression.
Re: 94 Delsol Si
Ok i understand i need to turbo the car. I had plans on getting a turbo kit this summer.
But there's nothing i can do to increase performance till then?
grumblemarc: i had plans on getting a 5 speed but i need to research and see what fits.
Re: 94 Delsol Si
not that it will help much
you can get it ready for the turbo
like getting an exhaust installed
get lighter wheels and good tires that will keep you on the road when yo do get that turbo.
you can upgrade injectors to RDX ir ID type with better spray pattern.
turbo will need completely different set of parts than NA.
whatever you buy now will not work for the turbo setup
Monarch
01-30-2002 06:58 AM
