Help with Apexi Tachometer Decs !!!
Old 02-23-2013, 05:41 PM
Dtay's Avatar
Icon2 Help with Apexi Tachometer Decs !!!
Hi People ! Please someone can Help me ?
I just bought one Apexi Tachometer Decs white background and installed correctly as manual says. First impression works fine... okay ...
RPM works fine, EL ilumination works Fine, Peak mode is working, I set de Shift light and works fine too... but when I press the Warning button while pressing the switch button the setup of temp and press not works, i cant set nothing and the annoiyng noise "pi pi pi pi pi pi pi" is killing me (lol)...here is the question my switch button is not working or I need install both sensors to enter de mode of config press and temp ?
I just install de oil press sensor, the temperature I will intsall inside carter drain bolt.
Thankx a Lot .... here in Brazil we dont have so much support of manufacturers and we need to search and learn !
Dtay is offline
Old 08-01-2014, 01:01 PM
alangagu's Avatar
Default Re: Help with Apexi Tachometer Decs !!!
Hello, i would like to know if you solve the problem. Because i've got a apexi tachometer also. I see you are from Sao Paulo and i'm from peru. Maybe we can speak in portuguese or in spanish. Thanks
alangagu is offline
Old 08-01-2014, 01:03 PM
I never narc'd on nobody!
NotARaCist's Avatar
This thread is a year and a half old. Don't bump old, dead threads. In the future, PM the OP.
NotARaCist is offline
Old 08-01-2014, 05:13 PM
The Grumpiest
grumblemarc's Avatar
Don't know why none of the tach owners bothered to go the the Apexi website, get the contact info and ask them?
http://www.apexi-usa.com/contact-us/
grumblemarc is offline
Old 08-02-2014, 08:35 AM
Hysterically Calm
TomCat39's Avatar
Expressed perfectly and is 100% correct for this site.
TomCat39 is offline
GoldLudeRay
Engine Management and Tuning
12-30-2013 02:10 PM
R spec
02-06-2004 01:07 PM
bulori
11-11-2002 10:42 AM
BoMeXCTR
06-04-2002 04:42 AM
Quick Reply: Help with Apexi Tachometer Decs !!!
