vtec conversion questions
The Grumpiest
Re: vtec conversion questions
I thought it was VTEC.
D15Z7
3-stage VTEC
Found in:
1996–1999 Honda Civic VTi EK3 and Ferio Vi
Displacement : 1,493 cc (91.1 cu in)
Piston Code: P2J
Bore and Stroke : 75 mm × 84.5 mm (3.0 in × 3.33 in)
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
Power : 128 hp (95.4 kW, 130 ps) at 7,000 rpm
Torque : 102 lb·ft (14.2 kg/m, 139 Nm) at 5,300 rpm
Valvetrain : SOHC VTEC (3-4 valves per cylinder, depending on engine speed)
VTEC Switchover : 5,800 and 6,200 rpm
Fuel Control : OBD-2 MPFI
ECU Code : P2J
Manual Transmission ECU Codes : P2J-003 (OBD2a), P2J-J11 (OBD2b)
Lean burn capable.
D15Z7
3-stage VTEC
Found in:
Piston Code: P2J
Rod Length : 137 mm
Rod/Stroke : 1.62
Compression : 9.6:1
ECU Code : P2J
Lean burn capable.
i bought it off a honda mechanic and he said it has a D15Z7, he said the block had 200,000+ miles and head 100,000 miles so it has a different head. i didnt know the block was a vtec motor. its my first civic so im all new to hondas i bought it for fuel economy and to have cheap fun and its a project at the same time.
so i wont gain any power going to vtec? and i have another question i need to fix the rear 1/4's has any one used fixmyrust.com before for panels?
Seagull Management
You'll make some power, but it's certainly not a night and day difference.
I haven't bought from fix my rust specifically, but I have bought the replacement quarter panels before. They're a great way to fix a rotten quarter panel and if you sort of know what you're doing you can make it look pretty decent.
fixmyrust.com is $30 a 1/4 panel is that too cheap?
http://www.fixmyrust.com/Category/GB
finally got it to my shop and took a few pictures.
im too embarrassed to show the other side were 2 owners ago hit a side rail. what do you guys think for $1400?
