still having a brake light issue.
i've posted about it before with no results.
i have a 94 eg coupe my brake lights stay on i've replaced the switch i have the rubber piece in there still, i'm thinking i have a messed up ground, where would a good place to start looking be? oddly though a few weeks ago i put my car in reverse and my third brake light came on. hasn't done it since then but, some of the things that happen are like when i put a fuse into the fuse slot the for the brake lights it gives a little spark. is there a ground for each individual fuse? i'm at a loss it's been a few months and i have to drive this car everyday back and forth to work. it's not very safe. please help.
Re: still having a brake light issue.
ok am i supposed to test both at the same time? or one at a time? and i've had a few people tell me to adjust my brake pedal but i don't see why they tell me to the switch is fully suppressed unless there is a second switch that i don't know about.
the switch itself is adjustable. there should be a adjusting lock on the brake switch.
http://torontohondaparts.com/Part.as...=36750-SR3-003
Ok thanks I'll post on this again in a few days when it's not snowy cause of the snow storm in the Midwest.
so i don't have a multimeter and none of the mechanics at my shop do either which i thought was weird but, they had a test light so we played around with it for a while and then i unplugged the trunk wiring harness and tested the plug for each wire with a test light and it never came on. so i'm starting to think it's just getting a positive feed from another wire in the trunk some where cause all the wires are kind of messed up as it is. so i'm gonna buy a new trunk wiring harness and see if that fixes it. cause 2 other mechanics tested it with me and it's not the switch. does that sound right to you guys? since the test light wasn't being light up from within the plug? the brake lights even stayed on when we had disconnected the switch.
Buy a cheap digital multimeter, anything will do. Harbor Freight Tools has them for $4. Um, your mechanic doesn't have a multimeter, seriously?
so i tested my fuse voltage for the brake light/reverse and it was 12.76 i know i should've replied to this 2 months ago but that's what it is.
also i noticed when i had first got the car if i used my horn more than 2-3 times the fuse would blow along with my dome light fuse.
Roy Rogillio
08-29-2018 02:47 PM
civicflow
10-17-2007 03:54 PM
