94 hatch cx brake swap help!!
Hey people i bought a cx hatch with rear disk conversion and i wanted to buy some drilled rotors i wanted to know if the rear rotors are biger than front ones.
All integra rear disk are bigger than cx civic right?? But same size as ex and si??
So the deal is that i want to swap the cx front suspesion to an ex so i can buy the drilled rotors as a set of 4 and have no problem installing.
What is the difference between the cx and ex/si front suspension
I know that ex use bigger rotors caliper and has abs
What do i do with abs are the brake lines longer or same size?does it bolt right up?
Any other info would be helpful
Plz just reply if u are going to help dont tell me to search im done searching not all problems are the same by sound the same but they are not
Location: Pensacola, FL and every Court House in Louisiana
Re: 94 hatch cx brake swap help!!
No one is going to spoon feed you!!! Try searching the suspension section!!! There is a sticky with all you need to know. Drilled rotors are worthless and dangerous unless your just going for looks. Keep to the blanks!!!
The CX doesn't have rear discs, so you can't say they're smaller or bigger than any other car. They don't exist. If your car is rear disc swapped, good for you, it doesn't matter.
If you're trying to install front drilled rotors, you want to find rotors made for your chassis. It isn't that hard. Rotors also aren't sold in packs of four, so you shouldn't have to worry about that. Just buy rear rotors to match the donor car, and front rotors to match your chassis.
CX's didnt come with rear disk...
Makes no sense at all
Ummm...everything is bigger......
Not all ex's came with abs
Lines are the same
Lines are the same
It was a little too nice lol. For some odd reason this spoon flew into my hand and took over.
Actually I think he is talking to the Op for telling people to not tell him to search because he doesnt want to. So yeah he is lucky he has not been flamed for being too lazy!
dE.fUsEd
06-20-2011 03:22 PM
ROOROWNS
03-20-2005 08:49 PM
