98 civic cranks no start
Old 02-19-2013, 04:33 PM
olegles11's Avatar
Default 98 civic cranks no start
i have a 98 civic lx
and my grand father 99 civic ex.
couple of weeks ago
his civic had(still has) the same problem it was running great , but all of a suden one morning it didnt start . would crank but no go.
so i tested coil with ohm meter and it was good . spark is white .
so i check if fuel pump gives pressure (it makes sound when u put ignition on)
and i unscrewed bolt on fuel fillter(dirty way) it squirted a lot .
so i just left it until it gets warmer .(he doesnt really need it).
98 civic lx ,so yesterday morning i go to my garage and start mine , same thing it will crank but wont start.
changed spark plug , swaped for a different distributor both have good spark.
changed fuel filter , fuel pressure regulator.
tested wires with ohm meter with in specs .
heres wired part , when i crank it wont start. when i unplug injector power clips and crank it kinda starts and then shut offs.
what can you guys recommend
Old 02-19-2013, 05:20 PM
fonkernuckle's Avatar
Default Re: 98 civic cranks no start
So you are saying that you checked all spark plugs and they were wet with fuel?
Old 02-19-2013, 05:22 PM
olegles11's Avatar
they are wet , but not that wet ,wet.
how wet should they be ?
Old 02-19-2013, 05:35 PM
As long as all four of em are wet and not bone dry you can tell, I had a couple of injectors not working on mine and I had power to the injectors but no spray= no start.
Right off the top of my head I would check timing marks, If I had messed with the plug wires maybe I could have gotten them mixed up.
But if you have spark and fuel then the other thing that might be missing is compression.
I would see what my compression looks like in the cylinders.
Could it be that too much fuel is going into the cylinders from an injector/s not making it run.
Any chance that you got some rotten fuel--I would put some high octane fuel just in case.
Any chance that you might have gotten ffft up fuel.
Old 02-19-2013, 05:48 PM
olegles11's Avatar
ill grab a gauge tomorrow test compression.
i was thinking about too much fuel as well ,because when i disconnect power to injectors it kinda starts but shuts off ofcourse.
as for fuel i always tank at my local costco , and couple of my family members , never had a problem .
i was thinking that fuel is bad but i dont know.
i was changing valve gasket month ago , i check timing belt was like brand new , clean no wear and tears . could timing sliped ? (frustrated)
Old 02-20-2013, 03:45 PM
olegles11's Avatar
compression is good . any one had something similar ?
Old 02-20-2013, 08:12 PM
raider1qaz's Avatar
my 1996 civic did the same thing, it would crank on and i could get it on after a min or 2 then it wrmed up and ran normal,it was my coolant temp sensor, i have no idea why it was that
Old 02-20-2013, 08:16 PM
fleabag's Avatar
doesn't a bad main relay cause this problem?
Old 02-21-2013, 04:55 PM
olegles11's Avatar
u mean fuel pump relay ?
please give me more info
im bumped .
im ready to f* burn it j/k need to fix over weekend .
Old 02-21-2013, 05:01 PM
djdaveey's Avatar
have you check spark if ........ no spark timing coil inside distributor i had same problem those things all ways go out !!!!!
Old 02-21-2013, 05:09 PM
beecee18's Avatar
PGMFI main relay,
Coil/Ignitor,
Ignition switch,
ECU power/grounds (faulty connection, compromised wiring)
http://www.tegger.com/hondafaq/index.html
Use this helpfull resourse in determining what the problem is.
Old 02-23-2013, 09:42 AM
olegles11's Avatar
Originally Posted by beecee18
PGMFI main relay,
Coil/Ignitor,
Ignition switch,
k so today spend couple hours diagnosing .
spark is bright white , fuel pump primes , spark get wet ,
main relay gives three clicks ( tested with volt meter as well)
test injectors input with light (each gets a voltage)just grabed different compressin gauge
1 90 lbs per sqinch
2 60
3 80
4 90
is this bad ?
Tested with throttle fully open all spark plugs off .
Old 02-23-2013, 12:10 PM
fleabag's Avatar
yes that's bad however I'd imagine that even with such low compression numbers, the car should still be able to run, no? Maybe take some pictures of the spark plugs...? Btw so you're saying that when you're cranking the engine with the plugs inside and then take them out, the plugs smell like fuel?
Try the test again, do a wet and dry test... Might want to rent another tester just to be sure because this very likely could mean your engine is toast.
Old 02-23-2013, 12:49 PM
ek3turbo's Avatar
seen that yu can drop some oil inside of the 2 cilynder to see if the compression rise alil more they low because the engine is cold when yu do a compression test usually to get the exact compression suppost to be on normal temperature but since yu cant do it cus the car doesnt start... one question do yu try to give gas when the car is cranking? so see maybe it will fire?
Old 02-23-2013, 02:33 PM
olegles11's Avatar
damn , after doing compression test , i put plugs back in , connect injectors , connect distributor . starts like a new one.
so while doing compression some **** flew from plugs holes. so it might be extra fuel or something.
so summary i changed fuel filter , pressure regulator , spark plugs , spark plug wires.
so basically do a scheduled tune up.
Thanks a lot guys .
Last edited by olegles11; 02-23-2013 at 02:34 PM. Reason: ps today is warmer by 15 degres mayb it has to do some with this
Old 02-23-2013, 02:53 PM
fleabag's Avatar
Plugs were dirty, you probably didn't have a good ground for the spark plugs or something.
lovemyhonda1
09-18-2013 11:56 AM
garrettrauch
08-31-2010 09:44 AM
dalejrfan88
10-29-2008 12:35 PM
tdubbebawllin
07-19-2008 02:10 PM
Quick Reply: 98 civic cranks no start
