EG OBD1 ECU P06 connector pinouts in Helms or where?
D15B7 P06 ECU (stock '95 DX Sedan) - I want to be sure when I use the Helms for troubleshooting, I have the option to test pins at the ECU connectors. In the Helms manual, of course for some steps it has you use the Honda special breakout box, but I will never have a breakout box. Therefore (I have not gotten in there yet), I was trying to find if there was a correspondence between the ECU breakout box pins listed in the troubleshooting, and some diagram elsewhere in the Helms (92-95), that shows which pins on the actual connector correspond. For example, D11 for TPS, if I look at the ECU connectors is there tiny raised numbering on the connector plastic itself which corresponds? Or is there a place in the Helms I am missing? Thanks in advance!
Re: EG OBD1 ECU P06 connector pinouts in Helms or where?
The Helms manual has all of the ECU connector pinouts.
Is this what you are looking for:
http://www.phearable.net/tech/wiring...schematics.gif
