Go Back  Honda-Tech - Honda Forum Discussion > Honda and Acura Model-Specific Technical Forums > Honda Civic / Del Sol (1992 - 2000)
Reload this Page >
D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together?
Old 09-19-2004, 10:52 PM
Default D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together?
Im trying to piece together a nice build up and dont feel competent enough to build a block and it seems like people are only building d16y8's and d16z6 blocks
Ive already built my d16a6 head and am wonderring it it will bolt up to one of those blocks no problem and still aloow to to use the stock crx d16a6 tranny and stock crx motor mounts
Thanks
Traction is offline
Old 09-19-2004, 11:15 PM
SECURITY's Avatar
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (Traction)
Is this an EF? D components are all interchangable. Just Like B components. Just remember ones obd0, ones obd1, and the last is obd2. And the EF tranny is cable and 92 up is hydro.
SECURITY is offline
Old 09-19-2004, 11:35 PM
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (oh_crx)
Yes its all going into an 88 Crx Si
So I can buy a built d16y8 block, mate it absolutely no problem to my d16a6 head and mount my stock crx si tranny to the d16y8 block using the stock crx si motor mounts?
If this is possible Im going to be a happy ******* man
Traction is offline
Old 09-20-2004, 02:23 AM
murmur9's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Traction &raquo;</TD></TR><TR><TD CLASS="quote">Yes its all going into an 88 Crx Si
If this is possible Im going to be a happy ******* man</TD></TR></TABLE>
Why would you want to put a a6 on a y8 block? It can be done...now if your trying to just get your car to run, OKAY....but 108hp?? =o( a6
It will bolt up fine, only thing is that y8 is obd2 and a6 is obd1, also the Y8 comes with a Knock sensor on the block. might want to wire that up buddy.
murmur9 is offline
Old 09-20-2004, 05:10 AM
hondainspired's Avatar
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (murmur9)
yea i would just do somthin like a y8 or z6 block with a y8 or z6 head.... with stock crx tranny... no sence usin that a6 head that doesn't have near the flow of the y8 or z6
hondainspired is offline
Old 09-20-2004, 05:56 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">
It will bolt up fine, only thing is that y8 is obd2 and a6 is obd1, also the Y8 comes with a Knock sensor on the block. might want to wire that up buddy. </TD></TR></TABLE>
First off, the a6 from the 88-91 si is obd-0. The z6 is obd-1. Second,he already said that the a6 head he has is already built meaning it is not stock.
To the original poster yes what you want to do is fine everything will bolt up. Just change over the crx motor mounts to the y8 block. Do you have a built y8 block ready to go yet?
willyboyK20 is offline
Old 09-20-2004, 06:57 AM
devi1man's Avatar
I can't see why it wouldn't work. It's a little backward from the way most people do it though.
But what happened to the A6 block? You should have been able to have that short block reman'd.
devi1man is offline
Old 09-20-2004, 07:07 AM
devi1man's Avatar
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (devi1man)
http://www.citymotorsupply.com/top50.asp
$395.00 + shipping
That's just a stock rebuild though.
devi1man is offline
Old 09-20-2004, 07:22 AM
eg4matze's Avatar
its no problem to build this engine, I think it will be a great working engine
eg4matze is offline
Old 09-20-2004, 07:27 AM
Well I personally thought I was going to build the block of my A^ myself, but I got a deal of this built A6 head in pieces and I put it together, and its built to ****, everything is bulletproof.
But I cant find a D16a6 built block pre done for **** from anyone. People are only building the other D series
But ya d16y8/d16y7,d16z6, d16a6 are all interchangeable?
Just use my crx mounts on the other block and it drops right in like stock?
What if I wanted to buy a timing belt.... it would still be the same...?
Also, anything special on compression or clearances I should be worried about?
Thanks
Traction is offline
Old 09-20-2004, 08:26 AM
devi1man's Avatar
Oh hell, I forgot about the timing belt. That may be an issue. You'll probably have to do the opposite of a Mini-me on the timing belt too.
Again, I don't actually know anyone who ever did what you are planning but I see Z6/Y8 heads on D15B7s and D16A6s periodically so I have no reason to believe it won't work the other way around.
devi1man is offline
Old 09-20-2004, 08:46 AM
It will bolt up fine, only thing is that y8 is obd2 and a6 is obd1, also the Y8 comes with a Knock sensor on the block. might want to wire that up buddy. </TD></TR></TABLE>I love it when people spread misinformation......
Revolver is offline
Old 09-20-2004, 09:51 AM
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (Revolver)
thats what lifes about lol, seperate the bullshit
bump for a solid answer though
Also have timing belt whoes, would it work with a stock timing belt?
Traction is offline
Old 09-21-2004, 02:16 AM
murmur9's Avatar
What was misinformation? Oh, the a6 being obd1, ya MY BAD...its obd0 I learned something new. stock a6 came with 108hp. TRUE, Y8 has a knock sensor that he would probably want to hook up...TRUE. I said IT WILL BOLT UP FINE....TRUE
so I AM SOOO SORRY FOR SAYING THAT IT WAS OBD1 when I WAS WRONG. woo hoo....
And I know what the **** a built a6 head is....still why the **** would you want to throw on a built a6 head. you could throw on the y8 head and havebetter hp numbers. now that a6 being built could probably handle more psi for FI , but...than a6? BUT COME ON..... thats *** backwards. ask anyone
murmur9 is offline
Old 09-21-2004, 05:06 AM
yea seems a little weird but he prob. built the A6 and spent alot of money on it... so i say... dont waste that money...
Old 09-21-2004, 07:00 AM
MADEINIRAQ's Avatar
Default Re: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together? (hondainspired
the vtec block will most likely not have the oil control jet in the block. so take one from a non vtec block and put it in.. since you're using a non vtec head
MADEINIRAQ is offline
Old 09-21-2004, 10:43 AM
giddy up
Traction is offline
Old 09-24-2004, 01:49 PM
Traction is offline
Old 09-24-2004, 03:00 PM
senpai's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MADEINIRAQ &raquo;</TD></TR><TR><TD CLASS="quote">the vtec block will most likely not have the oil control jet in the block. so take one from a non vtec block and put it in.. since you're using a non vtec head</TD></TR></TABLE>
I was going to say the same thing. The z6,y8,y7 (ones I know of) have the oil jet in the head. The A6 does NOT; it came in the block.
senpai is offline
Old 09-24-2004, 03:12 PM
so what does that mean.... Im sorry but Im not familiar with internals other than basic, crank/rods/pistons, valvetrain...
Thanks
Traction is offline
Old 09-24-2004, 04:13 PM
Bserieskllr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by murmur9 &raquo;</TD></TR><TR><TD CLASS="quote">What was misinformation? Oh, the a6 being obd1, ya MY BAD...its obd0 I learned something new. stock a6 came with 108hp. TRUE, Y8 has a knock sensor that he would probably want to hook up...TRUE. I said IT WILL BOLT UP FINE....TRUE
And I know what the **** a built a6 head is....still why the **** would you want to throw on a built a6 head. you could throw on the y8 head and havebetter hp numbers. now that a6 being built could probably handle more psi for FI , but...than a6? BUT COME ON..... thats *** backwards. ask anyone </TD></TR></TABLE>
well most likely he will be running a pm6 or pg7 ecu which neither look for knock sensors so i dont see why you would wire it up, 2nd theres nothing wrong with a non vtec d-series.....the fastest all-motor sohc ares non vtec cause you can run a huge cam and the a6 flows better then a y8 head.....and the thing about the oil jet its this little thing you have to insert into a hold between cyl 2 and 3 im sure some1 can post a pic where it goes. good luck with the build
Bserieskllr is offline
Old 09-24-2004, 04:34 PM
so it isnt difficult?
Traction is offline
Old 09-24-2004, 04:55 PM
never done it but it looks pretty damn easy.
Old 09-24-2004, 05:15 PM
djwest24's Avatar
Here you go...
Pictures stolen from BauleyCivic's Mini-me writeup...hope he doesnt mind!
djwest24 is offline
Old 09-26-2004, 10:21 PM
Solbros Owns Me
Evs-One's Avatar
Why run a Y8/Z6 block anyways????
I for one, am building up yet ANOTHER SOHC engine...this time using a D16A6 block. Why?&gt;? Because it has steel mains. No other D16 had steel mains. All dimensions of the blocks are the same, cranks interchange, etc....but will be stronger.
Also, I love the A6 head....a nice port job and an aggressive cam makes for a very good NA setup for cheap! Especially for those race cars trying to stay competitive in their class
Evs-One is offline
'96typeR
11
08-29-2015 07:12 PM
j0keefe21
31
11-13-2009 11:49 PM
PROJECTEF9
08-09-2005 08:12 AM
slow91crx
01-11-2005 12:26 PM
crxsi8
10-22-2004 06:38 AM
Quick Reply: D16a6 Head -> D16y8/D16z6 Block -> D16a6 Tranny Cant they all fit together?
  • Ask a Question
Question Title:
Description:
