question about b20z
Old 09-20-2004, 06:38 PM
96cx's Avatar
Default question about b20z
guys... im looking at doing this swap but not sure of a fiew things...
1. could i get it smogged? ie BAR
2. what ecu do i use?
3. what axles?
4. what is average price you are all paying for this motor..
currently have 99 si tranny and this will be going into a 96cx. any help would be great... was also contemplateing about crvtec but not sure since it will be daily driven... would it be reliable still is my main concern. anyhow... any help would be great. thanks.
96cx is offline
Old 09-20-2004, 07:13 PM
Mag00n's Avatar
Default Re: question about b20z (96cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96cx &raquo;</TD></TR><TR><TD CLASS="quote">guys... im looking at doing this swap but not sure of a fiew things...
3. what axles?
1. Not sure
2. Most people use an LS ecu since they are easy and cheap to find. There are other you can use too though. This is assuming of course that you are not going b20vtec.
3. Any Bseries should do the trick. Im not 100% sure on that but I know for a fact integra axles work.
4. You should'nt pay more than 1000 for the motor, especially since you dont need a tranny. They can be had much cheaper but low mileage ones might fetch a high premium.
5. You will also need an LS intake manifold, as the b20 manifold will not clear your hood. Your also going to need the regular **** like motor mounts, bseries shift linkage, ecu, etc. I wouldn't go b20vtec if I were you unless you want to spend tons of time researching. It is not easy or cheap to build a b20vtec PROPERLY.
Mag00n is offline
Old 09-20-2004, 07:40 PM
CivicVX94's Avatar
Default Re: question about b20z (Mag00n)
no you cannot get it to pass. it is impossible to get any b20 to pass the bar when swapped in a 92+ civic for the b20a3 and a5 (must have same year of newer engine). and it is completely illegal to swap in a b20b or z into any civic of any year (considered small truck or suv engines)
CivicVX94 is offline
Old 09-22-2004, 08:36 AM
96cx's Avatar
Default Re: question about b20z (CivicVX94)
hey thanks for the info... it looks like imma have to go with a b18c then. thanks again
96cx is offline
codizz88
16
08-14-2014 09:38 PM
pinoy85
03-31-2013 09:56 AM
lcross
12-01-2007 10:44 PM
enasnitsi
04-18-2007 11:54 AM
hatchness135
08-05-2006 09:30 AM
Quick Reply: question about b20z
  • Ask a Question
Question Title:
Description:
