Re-Centering steering wheel
Re: Re-Centering steering wheel (R Thizzel)
Alignment shop, You propably dont want to mess with it due to the fact it more then likely means your alignment could be off.
Re: Re-Centering steering wheel (nocternaldragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">Alignment shop, You propably dont want to mess with it due to the fact it more then likely means your alignment could be off.</TD></TR></TABLE>
heres info that can help you,, https://honda-tech.com/zerothread?id=273474
just follow the first few instructions.
air bags dont alwayz save lives anywayz.. change the steering wheel also since ur doing that already.
Re: Re-Centering steering wheel (john666)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by john666 »</TD></TR><TR><TD CLASS="quote">
fwiw, the guy who was driving that car actually survived
be professional
just follow the first few instructions. </TD></TR></TABLE>
Um, no. You don't reposition the wheel on the column to correct an off-center steering wheel, unless the steering wheel was installed off-center to begin with. That's called addressing the symptom instead of the problem, a.k.a. "stupidity."
The car must be realigned to center the steering wheel.
Re: Re-Centering steering wheel (Targa250R)
thanks i was jus wondering if i could jus do it myself instead of payin 60 bucks to have the ********* at discount do it
its an alignment issue...get it fixed fast before your tires disappear. I had the same problem...took it to the 45 buck alignment place and now she's straigt as an arrow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">
The car must be realigned to center the steering wheel.</TD></TR></TABLE>
the tumbs up was for the quote the guy left b4 me. the link was answer to the ? that R Thizzel had.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocternaldragon »</TD></TR><TR><TD CLASS="quote">Alignment shop, You probably don't want to mess with it due to the fact it more then likely means your alignment could be off.</TD></TR></TABLE>
Yes just go to an alignment shop, For a front end alignment it should cost you anywhere from $45-60 bucks. Also I would check your tires alswell if your Steering wheel is out of whack your toe maybe as well.
be professional
Re: Re-Centering steering wheel (sleepyzze110)
That pic is real. Search and you will find the entire series of pics from the accident.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleepyzze110 »</TD></TR><TR><TD CLASS="quote">that pic sucks..
bye bye ITR seats</TD></TR></TABLE>
It's an EP3 Civic Si. Those are the stock seats.
go to an alignment shop. After i replaced my driver side axle, i noticed my steering wasnt straight anymore. It was a little off. Well, after months of driving like that, it was new tires time! I got new tires and told them to zero the toe. Got the car back, steering wheel was straight and the steering seemed a whole lot easier/lighter.
05civicdriver
Honda Civic (2001 - 2005)
13
04-13-2007 03:35 PM
ForceFed Motorsports
04-18-2006 06:55 AM
