Blew rod out of engine! Have a 97Ex D16Y8 can I use a D16Y7 Block?
Old 09-20-2004, 06:06 PM
ferchja's Avatar
Default Blew rod out of engine! Have a 97Ex D16Y8 can I use a D16Y7 Block?
Blew the #3 rod out the block like a Randy Johnson fastball through a pigeon. I was able to pick up a D16Y7 for cheap. I assume that I can swap out all my D16Y8 by stripping the Y7 and just moving the block over.
Is there anything I have to consider when swapping in the Y7 block?
Read the posts on this forum, so I am familiar with the fact that this is common swap for the DX guys to get VTEC.
Thanks in advance
Ferch
Modified by ferchja at 7:22 PM 9/20/2004
ferchja is offline
Old 09-20-2004, 06:08 PM
Electrician
Deemeetree's Avatar
It's VTEC, not v-tech. That's a phone.
Yes, you should be able to make a "Mini-Me". Swapping your cylinder head (if you didn't damage anything of it), and your intake manifold with all plugs and such should be fairly simple.
Search under "Mini-Me" and lots of information will come up.
Deemeetree is offline
Old 09-20-2004, 06:13 PM
ferchja's Avatar
Default Thanks
Thanks for the quick reply and the VTEC correction
ferchja is offline
Old 09-20-2004, 06:16 PM
Electrician
Deemeetree's Avatar
Old 09-20-2004, 06:54 PM
eg360B's Avatar
Default Re: (Dimi)
Modified by DreK914 at 9:32 PM 9/21/2004
eg360B is offline
mercenary.venom
09-11-2014 11:28 PM
Aykayek
15
01-09-2014 08:07 AM
02spoon
03-05-2008 05:23 PM
civictildeath
10-18-2004 06:29 PM
lmiguelvv
04-14-2004 11:21 PM
Quick Reply: Blew rod out of engine! Have a 97Ex D16Y8 can I use a D16Y7 Block?
  • Ask a Question
Question Title:
Description:
