Headlights are jacked
Ight i got some new bulbs and damn i jacked my lights up....when i drive at night i dont light the ground in front of me...i light the sky...no joke...how do i fix that??
Re: Headlights are jacked (Macky)
We need more information on your car. What year is it? I might be able to help but I need more info.
PS. Your still a trial user so use your 5 daily posts wisely.
Re: Headlights are jacked (DOHC4life)
Its a 98 civic hx...the bulbs i bought off of ebay and couldnt read the package(japaneese)...but there ultra white/blue lights
Okay I think your headlights are just out of alignment. Ill go take a picture of what you need to adjust to move them. DONT POST ANYMORE today unless its absolutely necessary. You dont have many left.
Okay, My digital camera is screwed right now so I will have to explain it to you. There are to things on the back of the headlight housing. One adjusts left/right the other is up/down. Best way to do this is to turn your lights on facing a flat vertical surface. Then just start turning the screws or gears on the back. Use a phillips head screw driver and turn them. If you still have your owners manual it should tell you which does which and the direction to turn them. If you dont, I could go look it up in mine for you. I hope this helps and good luck. If anyone could post the picture of the back of the 96-98 headlight housings would be awesome. I know its out there somewhere.
katb16vo
04-07-2004 11:37 AM
