EG coupe... HARD STARTING!!!
When cold... it seems like my EJ1 takes way to many cranks to finally start... i have a 10w30 castrol... and that is the only thing i can think of that is....
Re: EG coupe... HARD STARTING!!! (JDMisGOOD)
Dude 10w-30 is pretty thick for IL weather? I dont think thats the prob tho, It probably needs a tune, fuel filter, new plugs, air filter, or something along those lines
Re: EG coupe... HARD STARTING!!! (bbcnet)
naw... tune up consist of say.. fuel filter, air filter, plugs, wires, cap and rotor.... could even go as far as bleeding brakes, coolant and trans flushes... (a trans flush is what this car REALLY NEEDS)
Re: EG coupe... HARD STARTING!!! (hondainspired)
check the starter to see if any of the wires are loose, and the starter ground wire.
also check the battery, and the connections to see if theyre good
Re: EG coupe... HARD STARTING!!! (JDMvtecDRAGSTA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMvtecDRAGSTA »</TD></TR><TR><TD CLASS="quote">check the starter to see if any of the wires are loose, and the starter ground wire.
also check the battery, and the connections to see if theyre good</TD></TR></TABLE>
ooo those are good... like... good aditions to check... i know i've killed the battery about say... 4 times leaving the lights on... cause the car doesn't beep at me when my lights are on....
brutekiller787
27
02-18-2009 04:10 PM
bignosewhipper
16
07-03-2008 05:38 PM
dub204
08-16-2006 09:43 AM
