v-tec head on non v-tec block
Old 09-19-2004, 09:16 PM
baddog's Avatar
Default v-tec head on non v-tec block
i put a 1995 v-tec 1.6 on my 1998 1.6, set all of the timing marks, turned the engine over by hand 4 revs. then proceeded to start my engine only to here it run for about 2.2 seconds before it bent valves. i rechecked the timing marks and they were on the money. i looked at the old block and noticed there are slightly deeper indents in the v-tec pistons verses the non-v-tec pistons. could that be the reason for the bending of the valves? or was it pilot error and i just did somthing wrong. i have done several head gaskets on these v-tecs, but have never tried to put a v-tec head on a non-v-tec block. i was told that this swap was no problem. please help.....
Modified by baddog at 10:35 PM 9/19/2004
baddog is offline
Old 09-19-2004, 09:18 PM
MassScene's Avatar
Default Re: v-tec head on non v-tec block (baddog)
You hit the nail right on the head.
MassScene is offline
Old 09-19-2004, 09:20 PM
SOHC4life 96's Avatar
Default Re: v-tec head on non v-tec block (MassScene)
So you dont get flamed next time VTEC. No "-" or H at the end. And yes your right about the pistons.
SOHC4life 96 is offline
Old 09-19-2004, 10:11 PM
baddog's Avatar
Default Re: v-tec head on non v-tec block (DOHC4life)
i have the head off of the 98 with the ecu. could i make it work in place of the v-tec. i have the 98 computer also. so, three peaple told me that this would work with no valve issues, does this mean three peaple were wrong, and that there expertice just cost me a $300 head plus labor, and yet i have gained more experiance in this field. ha ha. all i wanted to do was fix this car so it would run, and sell it.
baddog is offline
Old 09-19-2004, 10:37 PM
when you set the makes did you use the TDC whit mark or the red?????
civtegra_hybrid is offline
Old 09-20-2004, 09:21 AM
baddog's Avatar
Default Re: v-tec head on non v-tec block (civtegra_hybrid)
i used the white mark. but when i first set the timing i used the arrow on the oil pump and the line on the lower gear.
baddog is offline
NocsCtr
08-11-2006 03:14 PM
NocsCtr
08-08-2006 03:50 PM
baddog
11-17-2004 08:48 PM
lillthingz
17
08-14-2004 04:58 PM
94accord1985
01-07-2004 03:09 AM
Quick Reply: v-tec head on non v-tec block
  • Ask a Question
Question Title:
Description:
