tranny fluid
Re: tranny fluid (R Thizzel)
As said before me, the drain plug is on the bottom side of the transmission, it accepts a direct 3/8" Ratchet head.
The fill HOLE on my 92' Civic DX tranmission, is actually the same hole the dipstick goes into. You'll need a long neck funnel to reach it.
Electrician
No problem.
3/8 Drive for the Drain Plug.
17mm for the Fill Plug.
Also, use one of these to fill it. Makes it MUCH easier plus you have gravity on your side.
Made it for $2.50 and 2 minutes.
Re: (Dimi)
How in the hell are you suppose to fill the transmission from the side? well.. with a tube ofcourse. .. well I got the idea it was suppose to go into the dip hole from what the manual said, it never mentioned a 'fill hole' on the side... I'm still OK right? I have an Automatic though.
Electrician
Re: (Paprika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Paprika »</TD></TR><TR><TD CLASS="quote">How in the hell are you suppose to fill the transmission from the side? well.. with a tube ofcourse.</TD></TR></TABLE>
Manual Transmission and Gear fluids come in bottles with a "nipple" at the top so you can tip the bottle over and squeeze. Doing this will get you nowhere and give you a hernia. Instead, you can be above your engine bay slowly pouring down the funnel and let gravity take over.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">No problem.
Made it for $2.50 and 2 minutes.</TD></TR></TABLE>
or get one of the syringe things...works fine
or maybe it was cause i have access to a lift at work
Electrician
Re: (itr_eg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by itr_eg »</TD></TR><TR><TD CLASS="quote">
or maybe it was cause i have access to a lift at work </TD></TR></TABLE>
You bastid.
Yeah, those thigs are called "Siphon" tubes.
You bastid.
Re: (Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">You bastid.
Yeah, those thigs are called "Siphon" tubes. </TD></TR></TABLE>
you learn somethin new everyday i guess
u can know the name of whatever u want, doesnt mean u know what ur talkin bout
Andrew14
21
06-28-2010 01:12 PM
