Electrical Problem?
Electrical Problem?
Here it is, plain and simple. I have a 96 Civic LX Sedan. Recently my A/C stopped working, my passenger window and my left rear window wont go down anymore and my fan wont start, which means my car starts to heat up. I checked all my fuses and they're all ok. What could be the problem? All your help is appreciated. Thanks guys. One more thing, now my driver side door wont go down automatically when I push the power doorlock button. Need Help Quick.
Modified by HondaCivicAddict at 5:02 PM 9/20/2004
Re: Electrical Problem? (HondaCivicAddict)
Did you do any electrical work before hand? Thats pretty ******* weird that your left rear window and your pass window is the only ones that wont go down anymore.
You checked even the under the hood fuses?
did you check the fuse's in the eng bay??????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ?????????????????????????????????????????????????? ??????
None of my fuses are out even from under my hood. I even bought new ones just in case and replaced them. And no I have never done any electrical work on my car.
Do any of your other windows go down?
How does your AC belt look.
Your pretty close to me if you want you could bring it by and i could take a look at it and maybe help you out. LMK.
Since your a trial user heres my info so you could email.
https://honda-tech.com/zerouser...19459
Check chassis grounds. You need to check to see if your fuses are getting power when they should (aka: power from teh battery, igntion switch). Check for burned or cut wires also.
You really need a Wiring diagram to find the problem fast(er).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCivicAddict »</TD></TR><TR><TD CLASS="quote">Where can I find one?</TD></TR></TABLE>
Helms
Helms
corozco83
09-11-2013 12:22 PM
