do it compression test but i see low
first the setup: y7 block whit pm7 pistons,z6 head whit zex 59300 cam....
test compression: dry test
1-170
2-180
3-170
4-160
only the numer 2 whit a litle oil in put 240 in the test
i have a bad headgasket i know(i replaced tomorrow have a big leak in piston number 4,water out of the head), but this affect the compresion test or my numbers are fineżżż???
1-170
2-180
3-170
4-160
Re: do it compression test but i see low (JDM Ninja)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDM Ninja »</TD></TR><TR><TD CLASS="quote">The numbers aren't too low, but I would still replace the headgasket if I knew it leaked.</TD></TR></TABLE>
Si...
Si...
Re: do it compression test but i see low (ERA)
Fix the headgasket then redo the compression test.
So far those numbers are somewhat good (there all 10s within each other which is what you want). Fix the gasket.
Edit: Also what did you mean you did a dry test and then a test with oil? Always have oil in the car when your turning it over.
Re: do it compression test but i see low (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">
Edit: Also what did you mean you did a dry test and then a test with oil? Always have oil in the car when your turning it over. </TD></TR></TABLE>
LOL... ****, I hope not
Re: do it compression test but i see low (ARAXIS)
[QUOTE=ARAXIS]
1-170
2-180
3-170
4-160
QUOTE]
why the **** didnt you have oil in there, YOU NEED to hit that NAAAWWWZZZZ bottle when youre running with no oil....that **** KILLS!!!!!! thats that osama bin laden, that straight KILLA
1-170
2-180
3-170
4-160
QUOTE]
Location: With my POS D15B2, Whereever whenever, United States
Re: do it compression test but i see low (yanta)
your engine has miles on it, expect it
back when i had my d15b
i for 160 on all 4, it was because it had 130k on it
expect it, its fine
expect it, its fine
Re: do it compression test but i see low (MugenHonda)
I believe when he says he put oil in number 4, he put oil in the combustion chamber to see if he had bad rings or not...
Re: do it compression test but i see low (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla »</TD></TR><TR><TD CLASS="quote">I believe when he says he put oil in number 4, he put oil in the combustion chamber to see if he had bad rings or not...</TD></TR></TABLE>
humboldt_skim
05-31-2008 08:18 AM
B18PoweredCivic
05-29-2003 03:57 PM
