99-00 fog lights
Old 09-19-2004, 06:46 PM
T.J.'s Avatar
Default 99-00 fog lights
Today i tried installing my oem fog lights on my 00 SI. I read the instructions properly and installed the harnesses. When i hit the switch i had no luck the fog lights did not turn on. So i went back and double checked the install and it was correct. I then checked the fuses and they were fine. I then check the voltage on both harnesses and everything was getting voltage. Then i checked all the grounds. Everything was good. Then i was like what the hell. My friend came over today and i tried hooking the fogs up to his harness and the fogs worked fine. My only thought is my A/c, power steering, cruise control, and winshiels washer fluid are disconnected also my radiator fan is hard wired. Could any of these parts being disconnected affect the fog light harness. Also all the grounds for these parts have been reconnected. So what is wrong why are the fogs not working
T.J. is offline
Old 09-19-2004, 08:04 PM
T.J.'s Avatar
Default Re: 99-00 fog lights (T.J.)
bump
T.J. is offline
Old 09-19-2004, 08:46 PM
crazy eyez killa
Guest
Posts: n/a
they only work when your headlights are on
Old 09-19-2004, 08:57 PM
98k20ex's Avatar
i didn't use the harness that came with the kit i just hardwired them myself. it's a lot simpler
98k20ex is offline
Old 09-20-2004, 06:13 AM
ek_will's Avatar
Default Re: 99-00 fog lights (98b16ex)
i hard wired mines had trouble with first i had to use a few different grounds but other then the rest which is simple thats the only thing i can think of. if its anything like my problems everything is ground related
ek_will is offline
Old 09-20-2004, 06:28 AM
benhatch101's Avatar
Default Re: 99-00 fog lights (dash_0n)
1st thing that pops in my head is a ground connection
benhatch101 is offline
Old 09-20-2004, 03:03 PM
T.J.'s Avatar
Default Re: 99-00 fog lights (benhatch101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by benhatch101 &raquo;</TD></TR><TR><TD CLASS="quote">1st thing that pops in my head is a ground connection </TD></TR></TABLE>
Yeah Thats what i figgured aswell but i doulble checked all the grounds and made sure they were connected . plus i did check the voltage on them as well
T.J. is offline
Old 09-20-2004, 03:04 PM
T.J.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98b16ex &raquo;</TD></TR><TR><TD CLASS="quote">i didn't use the harness that came with the kit i just hardwired them myself. it's a lot simpler
When you hard wired them what size fuse did you use to run them
T.J. is offline
Old 09-20-2004, 03:13 PM
haccord2.2's Avatar
It might be the grounds, depending on if there is paint behind the grounding point maybe it isn't grounding.
haccord2.2 is offline
Old 09-20-2004, 07:44 PM
T.J.'s Avatar
Default Re: 99-00 fog lights (haccord2.2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by haccord2.2 &raquo;</TD></TR><TR><TD CLASS="quote">It might be the grounds, depending on if there is paint behind the grounding point maybe it isn't grounding. </TD></TR></TABLE>
Nope no paint behind the grounds, im using the grounds that directions call for
T.J. is offline
Old 09-20-2004, 08:22 PM
New User
Newman's Avatar
Does the relay click when you give it power?
Newman is offline
Old 09-21-2004, 02:36 PM
T.J.'s Avatar
Default Re: 99-00 fog lights (Newman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Newman &raquo;</TD></TR><TR><TD CLASS="quote">Does the relay click when you give it power? </TD></TR></TABLE>
NO i cant hear it clicking
T.J. is offline
Old 09-21-2004, 08:00 PM
New User
Newman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T.J. &raquo;</TD></TR><TR><TD CLASS="quote">
NO i cant hear it clicking</TD></TR></TABLE>
Then you either have a bad signal, bad lead to the battery, bad lead to a ground source, or the relay itself is bad. Try taking a wire and giving the relay power directly from the battery. If should click which tells you that it's working.
Newman is offline
Old 09-22-2004, 07:10 PM
T.J.'s Avatar
Then you either have a bad signal, bad lead to the battery, bad lead to a ground source, or the relay itself is bad. Try taking a wire and giving the relay power directly from the battery. If should click which tells you that it's working.</TD></TR></TABLE>
ok ill try that
T.J. is offline
Old 09-22-2004, 07:19 PM
99redb16a's Avatar
i have a 99 civic si, and i was wondering where I could purchase those fog lights
99redb16a is offline
Old 09-22-2004, 07:20 PM
EK k kay's Avatar
Default Re: 99-00 fog lights (99redb16a)
EK k kay is offline
Old 09-22-2004, 08:46 PM
stock99's Avatar
i got mine from handa-accessories.com
stock99 is offline
ironworker
Honda Civic (2006 - 2015)
06-04-2009 02:39 PM
CHAMPwhteEK
04-03-2009 02:13 PM
ttk3
08-20-2007 07:01 AM
ITLNstallion818
08-14-2007 09:20 AM
member99-00
07-04-2004 09:43 PM
Quick Reply: 99-00 fog lights
  • Ask a Question
Question Title:
Description:
