D16Z6 SWAP INTO 94VX Please Help
Last night we swaped in a d16z6 into my vx and we hooked up everything and bolted everything up correctly and when we started it up when we were done the engine would crank and turn over but i would die. It would also start for a lil bit then die. Can you guys help me out and see what could be the problem. Everything plugged in. I used the vx harness and a p28ecu. All comments are appreciated. Help a brotha out and blow up this thread.
Re: D16Z6 SWAP INTO 94VX Please Help (meanTheDope)
ok now it runs but the vtec does not kick in...the ecu is also throwing a code 41 which is the o2 but i dont think that will effect the vtec. what could be the problem? all suggestions are highly appreciated. thanks
Re: D16Z6 SWAP INTO 94VX Please Help (nsxmatt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxmatt »</TD></TR><TR><TD CLASS="quote">You need the Z6's 4-wire 02 and you'll have to run all 4 wires to the ecu.</TD></TR></TABLE>
gotsol607
12-03-2007 07:42 AM
