EK auto->Manual question (ECU related)
Im going to be changing out my auto tranny on my 96 Y7 with a manual tranny... Im also going to be using an OBD 1 p28 ecu with a JDMshit OBD2->OBD1 harness... Am I going to run into any problems as far as IACV or any other problems of this sort because Im using an OBD 1 p28 ecu? BTW im using the p28 ecu because (1) its manual and (2) will be chipped soon as I join the d series turbo ninjas
TIA
Also will I throw any codes because i'll be using a vtec ecu on a non vtec motor? (i think so... just looking for confirmation)
TIA
Re: EK auto->Manual question (eg4matze)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg4matze »</TD></TR><TR><TD CLASS="quote">obd1 ecu dont work with obd2 injectors and distributor, buy a obd2 ecu or obd1 distributor and injectors</TD></TR></TABLE>
Thats not true... I know this for a fact because I know people with obd2 b series motors in their cars running an obd 1 p28... and I can start my own car with the p28...
it'll work if he jus uses the ECU jumper from any of the new Various companies that make them now....
you will have to move a wire in the ECU clips (obd2 side) for the IACV to function properly or you will throw a code. i'll find otu which one exactly cause it's been a while snice i did one
Re: EK auto->Manual question (JohnX6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnX6 »</TD></TR><TR><TD CLASS="quote">it'll work if he jus uses the ECU jumper from any of the new Various companies that make them now....
you will have to move a wire in the ECU clips (obd2 side) for the IACV to function properly or you will throw a code. i'll find otu which one exactly cause it's been a while snice i did one</TD></TR></TABLE>
Thanx man i'd appreciate it....
MaxxdoutSRT4_EK9
06-26-2005 10:23 PM
