NEED help SETTING UP VAFC NOT TUNING ANYONE?????????
i need help with the initial setup meaning
i have 00 civic si..
1. setting sensor number
the sensor number default is 06 in 06 out... what would i set this to and why?
2. setting the vehicle type
i know i set the cyclinders to 4.
the throttle sensor i am unsure what i set that to ???
and what vtec type do i have
3. display scale
what should the pr ne and cr values be? ????
4. sensor check.
i guess i just run this to test the prssure and throttle sensor voltage?
5.setting the warning
i want my rev warning prolly at 8200 aand i am unsure what the intake pressure warning should be???????
6.vtec v/t info
L->H settings
Prs settinngs
Thr settings
H-> L settings can i change these or is this just info???????
7. setting and changing the password
i can handle this one
8.vfd brightness i can handle this one too
9. program version check
10. all data initialization.. yes or no
3. display scale
4. sensor check.
6.vtec v/t info
L->H settings
Prs settinngs
Thr settings
Re: NEED help SETTING UP VAFC NOT TUNING ANYONE????????? (madlion)
set the sensor type to both 6 and 6, the cylinder type to 4 wit the arrow facing at an angle up towards the right, before you turn the car on do throttle self learning closed throttle for 10 seconds W0T for 10 seconds, shut ignition off, good to go...leave ALL tuning up to a skilled professional, you changing settings could harm your car, also most likely will lose power.... that initialization is only for if you tuned it and you want it to be at stock settings, if you messed with anything go to yes and let it initialize,a nd go back and do what i just told you to do...
Re: NEED help SETTING UP VAFC NOT TUNING ANYONE????????? (FBPsi7)
thanks.. and the self learning throttle response.. do i just mash the gas for 10 seconds.... redline it or what ???
the throttle self learning is def. supposed to be done with the engine off...After that you should be good to go, no problem man
madlion
09-18-2004 03:31 PM
freeplay
02-07-2003 08:39 AM
