Tranny question
Old 09-20-2004, 09:39 AM
SpoolinEK9's Avatar
Location: Seattle/Ligonier, WA/PA, United States of Honda
Default Tranny question
I put in my ls motor and tranny last night havnt started the car yet but all i have left to do is the wiring harness, but i am having a little trouble with the trannsmission i have the shift linkage hooked up and when i go in the the car and push the clutch in and try and move my shifter around while its not in gear its really really hard and then its the same when i try and get it into gear its really really stiff.
SpoolinEK9 is offline
Old 09-20-2004, 09:44 AM
jdm123's Avatar
Default Re: Tranny question (SpoolinEK9)
transmission fluid maybe?
jdm123 is offline
Old 09-20-2004, 09:47 AM
Sliced Beard's Avatar
Default Re: Tranny question (jdm123)
try loostening your shift lever a bit.....I am willing to bet that you over tightened it and it is now not wanting to move
Sliced Beard is offline
Old 09-20-2004, 10:14 AM
eK9aT10pSi's Avatar
Default Re: Tranny question (DirtySol)
what linkage are you using?
eK9aT10pSi is offline
Old 09-20-2004, 10:33 AM
Default Re: Tranny question (eK9aT10pSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eK9aT10pSi &raquo;</TD></TR><TR><TD CLASS="quote">what linkage are you using?</TD></TR></TABLE>
does not matter, problem has been solved
he was using a Civic shifter with Integra linkage......the shifter is narrower and he used washers and overtightened it......problem solved
hondaPINK
17
05-17-2006 06:09 PM
TylerC
11-16-2005 05:29 AM
743power
17
10-25-2003 06:04 AM
743 Stunna
10-19-2003 09:58 AM
SLOW4drINTEG
08-05-2003 04:27 PM
Quick Reply: Tranny question
  • Ask a Question
Question Title:
Description:
