Intake Manifold question
Old 09-19-2004, 09:55 PM
mengy007's Avatar
Default Intake Manifold question
I replaced my IM gasket today, I have a mini-me d15b7/d16y8 head.. with z6 intake manifold, LS throttle body. Everything was working fine before.
Now, it starts up revs to 4k then drops to 1k then 4k again and back... sounds like a sensor problem to me but I can't pin it down to which one... anyone have any idea what might be wrong?
mengy007 is offline
Old 09-19-2004, 10:06 PM
ej1 pilot's Avatar
Default Re: Intake Manifold question (mengy007)
sounds like a problem with your IACV (idle air control valve), you may need to replace it
ej1 pilot is offline
Old 09-19-2004, 10:10 PM
mengy007's Avatar
Default Re: Intake Manifold question (Art In Motion)
shoot i hope i didn't get any coolant on it and short it out... thanks though
mengy007 is offline
Old 09-19-2004, 10:22 PM
ej1 pilot's Avatar
its not exactly a sensor or wire its a little short thin valve sticking out of the back of the intake mani i dont think it can be shorted out
lol I know for a fact that you have an intake manifold leak, there's a way to find out for sure and loc. it, first take off your intake pipe, and then with the car on. cover the TB(throttle body) with your and, (it mite try to suck your hand in, but use your palm, also it will start to hurt after a while but it won't kill you) and if the car turns off, then your don't have a leak, but if your car keeps on running, that means there's a leak and you will be able to hear where it's cumming from, (that's the only place it will be able to suck the air), after that, then just replace the gasket that's leaking, also it's a good thing to scrap off ALL!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! of the old gasket, or it will cause it to leak. good luck
civtegra_hybrid is offline
Old 09-19-2004, 10:33 PM
also what gasket did you use, the one for the z6 or the y8???????? cuz the y8 head is diff. and you need to use the Y8!!!!! ITM gasket
Old 09-20-2004, 05:48 AM
mengy007's Avatar
Default Re: Intake Manifold question (civtegra_hybrid)
Well before it had the z6 gasket on and it worked so i thought the same one would be okay
thanks for all the replies
mengy007 is offline
Old 09-20-2004, 06:29 AM
benhatch101's Avatar
IACV or TPS sensors both in the same area in the rear behind the tb
benhatch101 is offline
Old 09-20-2004, 06:58 AM
madcrossover's Avatar
I had that problem with my throttle body, cause it would idle high then go down and back and forth and come to find out I took it to get fixed, it was my gasket between the throttle body and intake manifold. Hope that helps.
madcrossover is offline
Old 09-20-2004, 11:16 AM
mengy007's Avatar
Default Re: Intake Manifold question (madcrossover)
I'll check my gaskets when I get home from work. Thanks guys for all the replies.
mengy007 is offline
supra_japtypeR
10-27-2013 02:58 PM
94civicdeleon
04-12-2012 11:41 PM
99redSIR
06-25-2007 01:49 PM
Quick Reply: Intake Manifold question
  • Ask a Question
Question Title:
Description:
