Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
Old 04-05-2005, 12:55 PM
hondaowner's Avatar
Default Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
Guys,
Pardon for my lack of expertise.
Why does the coolant need to be drained for Timing belt replacement ? Honda civic 97.
Appreciate the education.
HondaOwner
Old 04-05-2005, 12:58 PM
flood's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (hondaowner)
Didn't drain it on my 98 ex. Just a little fill up from what came out when replacing the water pump.
ha, there ya go..thats why. when you replace your timing belt it would be wise to replace the water pump at the same time.
Old 04-05-2005, 01:31 PM
I forgot more about hondas then you will ever know....
Rodney's Avatar
Location: hop,skip, and a jump from the city,, new friggin york, USA
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (flood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flood &raquo;</TD></TR><TR><TD CLASS="quote"> when you replace your timing belt it would be wise to replace the water pump at the same time. </TD></TR></TABLE>
Old 04-05-2005, 01:35 PM
cool guy name
Sehc Tib Alli Zerif!!!!!'s Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (Rodney)
Yes, I would highly reccomend changing water pump when doing timing belt.
Old 04-06-2005, 02:03 AM
KayOs's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (walker111)
Don't forget the timing belt tensioner as well
Old 04-06-2005, 08:55 AM
hondaowner's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (KayOs)
you guys recommend timing belt tensioner too, What can go wrong with that on a vehicle that is already running ? Is it some bearing stuff ?
Thanks
Old 04-06-2005, 08:58 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondaowner &raquo;</TD></TR><TR><TD CLASS="quote">you guys recommend timing belt tensioner too, What can go wrong with that on a vehicle that is already running ? Is it some bearing stuff ?
Thanks</TD></TR></TABLE>
yes
Old 04-06-2005, 09:32 AM
RACEPAK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KayOs &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget the timing belt tensioner as well </TD></TR></TABLE>
nickysmalls
Honda Civic (2006 - 2015)
06-26-2017 08:28 PM
Ennis555
04-11-2017 09:21 PM
vtek9
09-02-2007 09:55 PM
NonovUrbizniz
11-15-2003 02:28 PM
MugenHonda
11-16-2002 08:47 AM
Quick Reply: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
