I have no brake lights or turn signals.?
Ive checked every damn fuse there is and still no go. I dont have the four ways switch plugged in, could that be an issue? headlights work, taillights work, running lights work, high beams, everything but the turns and brakes.
Also, the switch hooked up to the pedal is receiving 12v and when the pedal is depressed the dead wire receives 12v's as it should (to send juice to the brake lights).
i also did an integra dash swap,, but that shouldnt be an issue. they worked when i
was in the process of doing the dash swap. Now i cant figure the POS out... all grounds are good, but ANY info tips is greatly appreciated!
HELP!
HELP!
Re: I have no brake lights or turn signals.? (hatch34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatch34 »</TD></TR><TR><TD CLASS="quote">i think it is the hazzard switch</TD></TR></TABLE>
If the hazzard switch isnt fully in your turn signals wont work.
Dont forget to check your fuses under there.
Re: I have no brake lights or turn signals.? (Luserkid)
good call on the hazzard switch!!! bagged that problem! Now the brake lights,, bulbs are fine, wiring is good up front, ALL fuses are good. has to be somewhere from the switch to the lights...
i paid $800 for rolling shell, i guess this **** is gonna happen.
chris spies
12
01-16-2013 04:12 PM
Jameson
08-03-2007 04:00 PM
summey
02-06-2006 07:29 PM
supraUGlyy
04-19-2004 09:29 PM
