Oil Feed Line
Oil Feed Line
Hey all.. Is there another place to tap in the oil feed line and oil pressor sensor? My buddy recently picked up a b16 swapped eg coupe w/ a greddy turbo kit on it. And i guess while installing the oil feed line they managed to crack off a peice of the block where the oil pressure sender threads into. Its epoxied on there now but leaks of course. Is there another place to tap in for the oil pressure sensor/ turbo oil feed line? We will try to weld up the hole... lol..
O.G. triple O.G.
Re: Oil Feed Line (tissimo)
Look at the rear corner (cylinder head) near the oil cap. It should be a 1/8"NPT plug that you can unscrew and replace with a connector for your oil pressure gauge/oil feed line.
b18cya
02-19-2003 10:50 PM
MikeMAN
07-02-2002 09:25 PM
