Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
Old 04-05-2005, 11:36 AM
hondaowner's Avatar
Default Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
Guys,
Pardon for my lack of expertise.
Why does the coolant need to be drained for Timing belt replacement ? Honda civic 97.
Appreciate the education.
HondaOwner
hondaowner is offline
Old 04-05-2005, 11:48 AM
SiR AuToBoT's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (hondaowner)
it doesn't need to drain but when you change the timing belt you should also change the water pump, when you take out the water pump, coolant will come out from there and you will need to add more coolant to the radiator once you are done.
SiR AuToBoT is offline
Old 04-05-2005, 12:30 PM
Racermech's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (SiR AuToBoT)
why dont you ask in the civic forum?? the SOHC might be a little different than our DOHC's, unless you have an engine swap
Racermech is offline
Old 04-05-2005, 01:51 PM
95lstegman's Avatar
Default Re: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97 (Racermech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SiR AuToBoT &raquo;</TD></TR><TR><TD CLASS="quote">it doesn't need to drain but when you change the timing belt you should also change the water pump, when you take out the water pump, coolant will come out from there and you will need to add more coolant to the radiator once you are done.</TD></TR></TABLE>
95lstegman is offline
Old 04-05-2005, 03:47 PM
JamaicanDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech &raquo;</TD></TR><TR><TD CLASS="quote">why dont you ask in the civic forum?? the SOHC might be a little different than our DOHC's, unless you have an engine swap</TD></TR></TABLE>
same shytttttt but u dont have to drain the coolont system but u need to bleed it afterwards incase u have air bublles that can cause your car to run hot
JamaicanDM is offline
Old 06-25-2014, 02:43 PM
MartinRR's Avatar
when you remove the water pump you have less spilled coolant to deal with, and also you would have to bleed the cooling system anyways afterwards, it would be better to start with fresh coolant after bleeding it.
MartinRR is offline
Old 06-25-2014, 02:44 PM
B_Swapped93's Avatar
from 2005... cmon man that's 9 years!
B_Swapped93 is offline
Old 06-25-2014, 03:28 PM
TheRealTegger's Avatar
I heard the OP is dead from old age.
TheRealTegger is offline
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
It's the anniversary of coolant.
B serious is offline
Old 06-25-2014, 03:39 PM
It's the High Holy Day for coolant. Take your hat off.
TheeInitiative
07-02-2014 04:07 PM
kornerk12
11-27-2008 07:40 PM
erikiksaz1
08-27-2006 07:45 PM
hondaowner
04-06-2005 09:32 AM
Sephro
03-20-2003 11:19 AM
Quick Reply: Why the coolant need to be drained for Timing belt replacement ? Honda civic 97
