Did a swap in my EJ8...now no power to fuel pump..please help
SO I swapped in a JDM B16A using an SI wire harness. Now the fuel pump has no power. We checked the voltage and its 0.0. We have checked the fuses and tried new things with the ECU. We got a conversion harness for an OBD2A to OBD2B. We tried using the conversion harness and tried it without. Still no power. Any suggestions would greatly help. We are out of ideas.
Re: Did a swap in my EJ8...now no power to fuel pump..please help (boostedcivicsir)
Thanks man. Im going to definitely check that. Any other suggestions?
Re: Did a swap in my EJ8...now no power to fuel pump..please help (EKcoupe99)
do a search, should have something to do with ECU pins 15 & 16 being switched around
This was already mentioned but I cant stress it enough... Check your grounds and just for peace of mind, grind all your grounding points down to the metal.
I had a huge headache with my swap and it was all in the tranny ground
akinas-crx
15
06-01-2013 10:24 PM
2ndcoming
07-01-2007 05:30 PM
saigon1965
03-09-2005 11:02 AM
HYBRIDGSiR
06-01-2002 03:37 PM
