swapped ecu(p28) in vx and now cel
I swapped in a p28 ecu into my vx and now it's throwing out a cel light. Anyone know why it's throwing the cel light? Is it the o2 sensor?
Re: swapped ecu(p28) in vx and now cel (1 2 NV)
one of the harness on the passenger shock tower is missing the white wire for the 02 sensor to go to the ecu u need to add this wire from there to the ecu and that will fix it
Re: swapped ecu(p28) in vx and now cel (timnparts)
Is there any links or how to's on the 02 sensor fix? I tried searching but got almost 1000 posts of nothing.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by timnparts »</TD></TR><TR><TD CLASS="quote">one of the harness on the passenger shock tower is missing the white wire for the 02 sensor to go to the ecu u need to add this wire from there to the ecu and that will fix it</TD></TR></TABLE>
Checked the harnesses, didnt find any missing white wire. They are all there. Anyone got pictures or a link? Do I have to replace the o2 sensor also?
Re: swapped ecu(p28) in vx and now cel (flyazzcivic)
LOCATE THE 6 PIN PLUG BELOW ON THE PASS. SIDE VX SHOCK TOWER
The wires are in the following order:
ORG/BLU BLU/GRN WHT/BLK
BLU/YEL WHT/BLU YEL/WHT
REMOVE THE FOLLOWING WIRES FROM THE 6 PIN VX PLUG
ORG/BLU - O2 SENSOR
LOCATE THE 10 PIN PLUG PICTURED BELOW THAT IS ON THE VX SHOCK TOWER
BRN/BLK EMPTY BLK/RED
ORG WHT ORG/BLU WHT/BLU
BLU/GRN BLU/YEL EMPTY
[b]REMOVE THE RUBBER PLUG FROM THE UNUSED SOCKET
INSERT THE ORG/BLU (O2 SENSOR) WIRE INTO THE SOCKET BETWEEN THE BRN/BLK WIRE AND THE BLK/RED WIRE. (TOP CENTER SOCKET IN PIC)
ORG/BLU - O2 SENSOR
Followed that guide, removed the orange/blue wire and was going to tap it into the missing slot on the 10 pin harness but even if I tapped it in there, there was no wire on the other side. Now what? I'm still using my stock vx 02 sensor, should I replace that o2 sensor also?
Re: swapped ecu(p28) in vx and now cel (EGfosho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGfosho »</TD></TR><TR><TD CLASS="quote">why are you using a p28 ECU for a vx?</TD></TR></TABLE>
I think that the VX has a 1.5 Vtec...
OG Tech
Re: swapped ecu(p28) in vx and now cel (SkunkEk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkunkEk »</TD></TR><TR><TD CLASS="quote">
I think that the VX has a 1.5 Vtec...</TD></TR></TABLE>
Ya, but its a Vtec E. It's kinda different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flyazzcivic »</TD></TR><TR><TD CLASS="quote">swapped out the motor with an ex motor but still using the vx harness and o2 sensor...</TD></TR></TABLE>
probably would have been good info to put in ur first post...
If you end up needing one, i have like 3 4 wire O2 sensors...
OG Tech
Re: swapped ecu(p28) in vx and now cel (adictionbass)
i didnt see that post. if he is still using the same o2 from the vx he needs to change that. because the vx comes with 5 wires other than 4.
AdamITR
03-31-2003 11:38 AM
