I read the how to's at the top but no pics(brake swap)
I'm swapping out my rear drums on a 94 hatch with rear discs from a 93 del sol. Do I have to use the whole trailing arm assembly? Can I use the del sol e-brake cables, master cylinder, and prop valve also?
Re: I read the how to's at the top but no pics(brake swap) (teknics1)
yep, the whole trailing arm assembly.. e-brake cables..
you don't need to use the master cyclinder or prop valve.. well.. unless the prop valve is different.
zombieD
04-17-2010 04:41 AM
snowboarderguy44
11-14-2003 09:23 AM
Propulsion
03-24-2002 04:09 PM
