replaced clutch master cylinder, now two weeks later clutch pedal feels different
Motor: JDM B18C
Clutch: ACT XTSS
My Clutch master cylinder was leaking fluid from it, and it was really hard to get into gear, so i went a picked up a new one for 80.00.
Replaced the clutch master cylinder, leaks went away and it was now easier to get into gear..
latetly the clutch pedal pressure changes, sometimes it will be stiff and then sometimes it's way easier to push down.. Tried bleeding the clutch and theres no air in the system, just straight fluid coming out of the bleeder valve with no bubbles,etc.
What could be causing this?? Is it possible that the clutch slave cylinder isn't fully working?
Ideas? Comments? Suggestions?
* Tried searching and it's temp down.
Clutch: ACT XTSS
Re: (LSEGHATCH)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSEGHATCH »</TD></TR><TR><TD CLASS="quote">Maybe air? I don't know, just a guess so please don't flame me to harshly.</TD></TR></TABLE>
Already tried bleeding it..
im going through this same process as we speak. i have replaced first the slave, then master, bled the system...so right now i have it in my boys shop for an all over check up to see what it could be, i will keep you posted on what he finds out.
my final prognosis is that there was air in the line, but the kicker was that my pressure plate was so shot that it was not allowing the clutch to disengage tge trans. so exedy stage 1 will be installed tomarrow due to the lucky factor of local olympic auto having it in stock :<
DriveSideWays
08-27-2004 05:06 PM
FLCivic
06-30-2004 03:48 PM
