rear bracket (not mount) is it needed??
when i got my swap i took off the rear bracket thing that bolts to the intake manifold and then to the block, i coudlnt see any use for it at all except to make it a PITA to get the wiring harness off the motor so i took it off, just wanted to know if it really does serve a purpose or if its pointless. i know there are the metal hangers that u can clip some plugs on it but other than that, i cant see it doing anything..
sugestions?
sugestions?
Re: rear bracket (not mount) is it needed?? (CRXified)
I think you may end up cracking the intake manifold. It's just cast aluminum and it does have a lot of weight attached to it. I'd reinstall it to be on the safe side.
Re: rear bracket (spoonek9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoonek9 »</TD></TR><TR><TD CLASS="quote">I think you may end up cracking the intake manifold. It's just cast aluminum and it does have a lot of weight attached to it. I'd reinstall it to be on the safe side.</TD></TR></TABLE>
u know which bracket i mean tho right?
Re: rear bracket (CRXified)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">u know which bracket i mean tho right?</TD></TR></TABLE>
I know which bracket you are talking about. It's the intake manifold support bracket. I still say it's a necessary piece and should be reinstalled.
My friend and I have taken off that bracket on a few motors we built and ran and never had a problem. Maybe it's just luck but there isn't that much force put on the IM manifold to brake it when it's bolted to the head.
Not wanting to argue just saying that we never encountered any problems
Re: rear bracket (Mr.RHTuner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.RHTuner »</TD></TR><TR><TD CLASS="quote">My friend and I have taken off that bracket on a few motors we built and ran and never had a problem. Maybe it's just luck but there isn't that much force put on the IM manifold to brake it when it's bolted to the head.
Not wanting to argue just saying that we never encountered any problems</TD></TR></TABLE>
crazyguy
12
01-18-2008 04:13 PM
TuningOptions
03-08-2005 06:37 PM
Count Blah
01-20-2002 11:49 PM
