How do you replace an antenna?
How do you replace an antenna? I have a 96 Honda Civic and I'm trying to take out my old antenna. How do you do this? It there a guide online?
the antenna runs down the pillar and under the dash. if you have the new one that will tell you how long it is and where you might want to look for a plug. I honestly can't remember if it runs all the way to the back of the radio or not. After you have found and removed anything that might hold the antena in, tie a piece of string to the part under the dash, this way when you pull it through the hole in the roof you will have a lead to pull the new one through. they are kinda a pain to feed through. hope that helps.
Re: How do you replace an antenna? (awwsnap)
Go here:
http://www.hondaautomotiveparts.com/home.htm
Click on 'Honda Parts on-line'
Slect appropiriate Model, Year, Trim, Emission/Transmission and select "antenna-speaker" under the 'Component' pull down
You should have a pretty decent picture of the whole antenna piece.
HTHs
HTHs
austinwith96civic
03-11-2010 09:49 AM
graveltravel
10
12-02-2004 03:52 PM
